How can I tell if my Tacoma has been re-geared?
Discussion in '1st Gen. Tacomas (1995-2004)' started by PumpinIron, Feb 15, 2020.
  1. Feb 15, 2020 at 9:08 PM
    PumpinIron
    PumpinIron [OP] Well-Known Member
    San Tan Valley, AZ
    Picked up a 2003 Tacoma this weekend. It came with 285s, and since this is my first Tacoma, I have nothing to compare it to. Given the nice modifications on it, I have a feeling it's been re-geared, but since it was a trade in at the dealer, I have no way of knowing for sure.
    Is there any easy way to tell if it's been re-geared, and if so, what it was re-geared too?
    With the 285s, it seems to have plenty of get-up-and-go, so this has me wondering.
    It's a 3.4 with an automatic transmission.
    Did a search on this, but couldn't find a "conclusive" thread.
    Taco critter likes this.
  2. Feb 15, 2020 at 9:09 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
  3. Feb 15, 2020 at 9:26 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    mark the driveshaft and count rotations compared to 1 turn of the tire.
    Or open the rear and count teeth.
  4. Feb 16, 2020 at 12:41 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    What He said ^^^! this has worked for as long as I was alive.
  5. Feb 16, 2020 at 12:52 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    This is a very accurate method to determine gear ratio
  6. Feb 17, 2020 at 2:12 AM
    cazinpa
    cazinpa Well-Known Member
    Andy
    Lancaster, PA
    '96 Tacoma
    A few tweaks
    Not really mentioned above - just Jack up one wheel on the axle you are checking and leave the other on the ground.
  7. Feb 17, 2020 at 8:48 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    On the surface the previous posts sound logical but "differential action" must be accounted for.
    To correctly do this test one must first stipulate the type of diff along with one or both tires off the ground.
    1-With an open diff and one tire off the ground, it's DS rotations per two tire rotations due to "differential action".
    2-With a locked or limited slip diff it's one tire rotation but both rear tires must be off the ground. No "differential action" occurring.
    3-With an open diff and both tires off the ground some means would need to be taken to insure both tires equally turn one revolution (no differential action) and for that matter in the same direction. Double secret super pain in the ass, use #1.
