How can I tell if my truck has the TRD package?
Discussion in '1st Gen. Tacomas (1995-2004)' started by spasur, Jul 20, 2009.
  1. Sep 30, 2009 at 9:13 PM
    Tacoguy
    Tacoguy Well-Known Member
    Alex
    Chicago
    03 Tacoma PreRunner V6 3.4 TRD
    Bed Liner, Running Boards, Cargo Net, Deck Plate Mod, K&N Air Filter, NGK Iridium Spark Plugs
    I am not too sure about that. I have the TRD package on my 03 and I have Tokico Blue's. :cool:
  2. Sep 30, 2009 at 9:29 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Tokico shocks were included in the TRD Off Road Package instead of Bilsteins on 2001 - 2004 Double Cabs.
  3. Sep 30, 2009 at 9:42 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    I hope this will help you out or help answer your questions. This is a VIN number decoder pdf link, that may or may not tell you your options on your truck. I'm trying to get on it to see if it will tell you your options, but I can't get on it because of a bad internet connection. But when you can get back home you can look it up after you get the VIN number.
    But it will also tell you other useful things like where your truck was made, or color or whatever. I used it before but I can't remember if it told you your options.
    Here it is: http://www.weber.edu/wsuimages/autom...N%20Toyota.pdf
    xxTacocaTxx likes this.
  4. Sep 30, 2009 at 9:58 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Never mind, I finally got on but it doesn't show you if it has a TRD option or not. But I would suggest you still go on it and you can find out about other things on your truck.
    I would say that you may have to wait in till you get home to look at your truck and see if you can find that Diff. lock button. Or get under your truck to see if your rear Diff. looks like this:
  5. Oct 1, 2009 at 3:53 PM
    Turb0wned
    Turb0wned Well-Known Member
    Joel
    04 Tacoma Double Cab 4x4
    Im a bit confused on this topic... If I have a 04 4x4 and don't have the locker button I DONT have a locker correct? Is this a much didn't thing on a 4x4? My truck has 16' wheels and 265/70/16...
  6. Oct 1, 2009 at 4:10 PM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    If you don't have a locker control switch on your dash, you don't have a Toyota / TRD electric locker.
    The optional 16" wheels and 265/70/16 tires were bundled within the TRD Off Road Package as of your model year (2004), *BUT* they were also offered as a standalone option. So you could have the same wheels / tires as a TRD package without having the TRD package itself.
  7. Oct 1, 2009 at 4:58 PM
    Turb0wned
    Joel
    Ok thanks.
  8. Oct 2, 2009 at 12:50 AM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    I have a 99 "TRD" 3rz Manual, but the only thing TRD on it is the stickers on the bed, lol.
    The 4 cylinders as far as I can tell do not come with a differential locker, just better suspension (bilstiens).
    And since the shocks were replaced in my truck, the TRD stickers are just to look cool.
  9. Oct 2, 2009 at 8:04 AM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    The factory e-locker was never available (even with the TRD Off Road Package) on 4-cylinder automatics in the first generation.
    It was supposedly available with the TRD package on 1999 4-cylinder manual 4X4 XtraCabs.
  10. Apr 11, 2015 at 7:44 AM
    BlueManRising
    BlueManRising Member
    Nathan
    SC
    2015 SR5 Double Cab 4x4 MT
    Yellow Wire Mod, BenWA Rear window Mod, Equilizier Upgrade, Sub Install, Nerf Bars
    Sorry for the Bump on such a old thread, but I have a question regarding my 2015 that I would love some insight. It appears that the truck I have ordered, mind you selected from the ones that were available when they left Texas to go to the distributor, was originally supposed to be a TRD PRO. The reason why I know this is because when I was at the dealer trying to find one, they said that they could get the TRD before it made it to the distributor, and change it to a SR5 package. I guess here comes my question, I receive the car in a week, and per the VIN number that is already assigned to the truck, it should have all the TRD items, but will be marked as a SR5. I wonder if anyone would know if that means there going to give me a TRD differentials (locker/a-trac) but just not have them "fully installed". If you catch where I am going, the rear differentials are different from the SR5/TRD/TRD OR, so if I get lucky they will have the TRD Differential and hopefully its a few cheap parts at the dealer and I can get them fully functional. So ultimate question, has this happened to anyone? Thanks!
  11. May 17, 2015 at 6:33 PM
    LTC T
    LTC T Member
    Tacoma TRD
    So, is a Tacoma a TRD if it has the rear differential locking capabilty? I have a SR5 and the locking rear differential in my 2007. There are no TRD decals on the truck and the original owners manual is missing. I was told by the seller that it was a TRD.
  12. May 17, 2015 at 10:27 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    You'll probably get more responses if you post your question in the 2nd gen section. For most of use here, our knowledge of Tacomas stop with the '04 model year.
  13. Jul 10, 2015 at 4:18 AM
    kirkm
    kirkm Member
    Kirk
    2004 Double cab Tacoma
    2004 dblcab.trd sr5. Vin says trd. Has shocks, etc...but no switch. Was there a autolock or limited slip or something else? Is there something under the truck to look at that might tell me.
    Maybe gray wire mod was done and switch removed? Just can't explain why no switch.
  14. Jul 10, 2015 at 6:47 PM
    Digiratus
    Roaming the PNW
    The RedHead
    No.
    The e-locker actuator is mounted on the rear diff, on the drivers side on the front side of the axle next to the pinion.
    One explanation is, some TRDs didn't get the e-locker. For what ever reason, Toyota didn't include it in the package if the truck has a 4 cylinder and auto trans.
  15. Jul 10, 2015 at 6:57 PM
    #35
    kirkm
    kirkm Member
    Kirk
    V6. I think the diff has an actuator. Not sure y no switch
  16. Jul 10, 2015 at 6:59 PM
    #36
    kirkm
    kirkm Member
    Kirk
    If the rear diff is supposed to be used in 4wd low, y would a 2wd have it.
  17. Jul 10, 2015 at 7:06 PM
    #37
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    because toyota offers the locking rear diff with the 2wd prerunner models
  18. Jul 10, 2015 at 7:20 PM
    #38
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    My truck has a sticker and I think bilsteins. 03 5spd 4 cylinder
  19. Jul 10, 2015 at 7:41 PM
    #39
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    Since you have the V6 if your truck was a trd model you would have the e locker switch. Its really that simple. Look on the diff just like @Digiratus said if you want to be absolutely sure there is no locker
  20. Jul 10, 2015 at 7:43 PM
    #40
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
