How can my camber be maxed out for an alignment?
Discussion in 'Technical Chat' started by Sje1124, Oct 8, 2015.
  1. Oct 8, 2015 at 5:55 PM
    Sje1124
    Sje1124 [OP] Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Hey yall I've gotten a few alignments lately and was told that my camber is maxed out. Only problem is that it's maxed out at a negative .4 and .9. What can I do to fix this?
  2. Oct 8, 2015 at 5:56 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Heimed upper control arms.
  3. Oct 8, 2015 at 5:57 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    You've got front end sag it sounds like. I know worn coil springs can cause this
  4. Oct 8, 2015 at 5:57 PM
    Sje1124
    Sean
    Louisiana
    Just a few
    I have Desert Racing UCAs right now.
  5. Oct 8, 2015 at 5:58 PM
    Sje1124
    Sean
    Louisiana
    Just a few
    I hope my Icons aren't worn out after 15k miles....I'd be pretty upset at that.
  6. Oct 8, 2015 at 5:59 PM
    smmarine
    Melbourne FL
    Depends on how they've been used. Since you have after market parts I wonder if the alignment points are a bit different then stock points
  7. Oct 8, 2015 at 6:00 PM
    Sje1124
    Sean
    Louisiana
    Just a few
    90% highway. It's my wifes DD since I have a company car now.
  8. Oct 8, 2015 at 6:39 PM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    I don't see how your camber is maxed out with your caster being that high. You should be able to sacrifice Caster for camber. Pictures of your cam bolt locations would be helpful...
    looks like a Toe and go alignment
  9. Oct 8, 2015 at 6:43 PM
    Sje1124
    Sean
    Louisiana
    Just a few
    I can take pictures tomorrow morning of the bolts.
  10. Oct 8, 2015 at 8:10 PM
    smmarine
    Melbourne FL
    At least on my first gen, there is no adjustment for caster. Only toe and camber
  11. Oct 8, 2015 at 10:24 PM
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    I can't speak for 1st Gens, but there is a direct relation on 2nd Gens between the two
    Do that, it'll help!
