How capable is the TRD sport off road?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by shortyg83, Jul 30, 2021.
  1. Aug 3, 2021 at 7:06 AM
    #121
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    I off roaded my 3rd gen Sport with just better tires. It did just fine. The suspension was definitely not as good as the OR, but don't let anyone tell you can't off road a Sport.
    Thatbassguy and Slashaar like this.
  2. Aug 3, 2021 at 7:09 AM
    #122
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    Skeeeewp brings in the Rachels and Jennifers from Applebees and Red Lobster. But, I hear they may shit on your seat so, so locker vs:crapstorm:
  3. Aug 3, 2021 at 7:21 AM
    #123
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Same. Just pulled an F250 out of the mud/water. He was too big, so it wasn't really the TRD Sport that deserves the credit but if you find where the limit of the sport is and the OR will still go, you may be surprised. Lockers do make many low traction situations easier and lower risk, though. DCLB requires some careful line planning but I'd do it again given the choice.
    Slashaar[QUOTED] likes this.
  4. Aug 3, 2021 at 10:36 AM
    #124
    poopshute
    poopshute Well-Known Member
    Colorado
    2017 Tacoma TRD Pro Storm Trooper
    I haven't read through all of the posts here but I'll provide my experience.
    First off, I've never taken a sport off-road but that's irrelevant.
    I've owned 3 Toyota trucks in my life time. See below:
    Colorado trails, rocky, boulders, mountains, etc...
    1.) 1980 Toyota pickup 32" tires (in my avatar): No traction control of any sorts. I wheeled it just fine but had some issues with traction if I got in high articulation situations. If you know how to use your brakes to force traction to the wheel that's slipping, this works well. Not as good as a locker or sometime of limited slip. Also, airing down tires does wonders. Also, upgrading from the stock tires is huge (I've always preferred the BFG A/T KO2's).
    2.) 2000 Toyota Tacoma: Same situation as my 1980 except with 33" tires. No traction control of any sorts. When airing down the 33's, I had noticeably more traction. Still would slip in high articulation situations especially since the Tacoma's have independent front suspension as opposed to my 1980 that had a solid front suspension (solid front suspension keeps wheels on the ground better in articulation situations).
    3.) 2017 Toyota Tacoma TRD Pro: Ok, so I have all the bells and whistles (minus crawl control because mine is a manual). Front A-trac, rear lockers. Wheeling this truck with stock tires and lockers/a-trac on.... NEVER slipped. It made things easy in regards to traction. So easy in fact, I didn't have to worry about slipping, ever.
    Ok, the reason I went through this is simple. With my two first trucks with no traction control of any sorts, they were both capable off-roaders. You may need to bounce through things a bit more, you might have to play with your brakes a bit more... it's definitely less finesse when wheeling with a truck that doesn't have any traction control. However, the Sport does have limited slip and that will be better than my first two trucks. Sure you won't have ultimate traction like the OR and Pro, but you'll still have better than a truck w/out anything which should help get you through stuff. If you start wheeling on more gnarlier stuff, having a rear locker does wonders. Then again, if your definition of wheeling is going fast through dunes or small rollers, traction isn't important at all in regards to slipping and suspension is something you'll want to focus on.
    I'm not sure if this helped but long story short, your Sport will do just fine wheeling. It's just not going to be as easy getting out of harder lines and situations compared to an OR or Pro that has the rear locker and sudo-front locker (A-trac for example).
  5. Aug 3, 2021 at 10:43 AM
    #125
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    IT'LL EXPLODE! DON'T DO IT MAN!
    Kidding of course. It'll go almost everywhere a TRD OR will. Ask @Mrtacoman88 , he has a nice sport. The single biggest thing is the tires. Get a better set of tires from factory (doesn't need to be bigger, a more aggressive tread, the OR stock tires are a little better but not much, I love my falkens) and send it.
    Junkhead likes this.
  6. Aug 3, 2021 at 11:00 AM
    #126
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    Off Road
    Sport
    Kolter45 and AmateurTaco1313 like this.
  7. Aug 3, 2021 at 11:17 AM
    #127
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Sounds like a decent weekend plan. Hit Applebee’s, Red Lobster, and Cold Stone Creamery and load the Sport up with White Claws and singlemoms you met on Match.com “not looking for anything Serious”.
  8. Aug 3, 2021 at 11:31 AM
    #128
    TehWanderer
    TehWanderer Well-Known Member
    Northern WI
    2019 DCSB TRD Sport
    TRD Pro Skid RRW RR5-V 255/80/17 RCI Trans/tansfer case Skid Custom Sliders Eibach 2.0 lift Icon RXT soft topper
    The sport is very capable, did my first trip to Moab this May in my '19 Sport and made it through big name trails like, Hell's Revenge, and Fins N Fings, and more with some 265/70/17's and some armor no body damage just a scraped up hitch.
    Just go slow and work your way up you'll be surprised what the sport will do
    poopshute and Thunder Fist like this.
  9. Aug 3, 2021 at 11:45 AM
    #129
    IrishRed
    IrishRed Appalachian Ridgerunner
    Central PA
    2017 TRDOR DCSB 4x4 MGM Prem&Tech Auto
    Eibach Suspension, JBA UCA’s, 16” SCS Ray 10s, BFG KO3s, ECGS Bushing, Pro Skid Plate, Fumoto Valve, Pro Grille, Opt7 Tailgate Light Bar, AVS Window In-Channel Vents, Roknlokz XL Mud Flaps, Husky Floor Mats, Bed Mat, Tailgate & Glovebox Letter Inserts, TRD Grille Badge, Exhaust Tip, Toyota Hitch Plug.
  10. Aug 3, 2021 at 12:39 PM
    #130
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    The expression on your face just tells me I am right lol.
  11. Aug 3, 2021 at 12:57 PM
    #131
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    The truck is only as capable as the driver.
    What are your off-road capabilities???
  12. Aug 3, 2021 at 1:13 PM
    #132
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Pff. It’s not even Trail Rated.
    dnlskier and tacotoe like this.
  13. Aug 3, 2021 at 1:22 PM
    #133
    clg
    clg Well-Known Member
    2017 Off-road
    Posts like this are why the 3rd gen forum is for laughs and LED upgrades only.
  14. Aug 3, 2021 at 1:42 PM
    #134
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    To answer your question:
    In the hands of an experienced 4 wheeler, a stock TRD sport is slightly less capable than a stock TRD Offroad.
    In the hands of your average TW 3rd gen forum member, it doesn't make a fucking difference.
  15. Aug 3, 2021 at 1:49 PM
    #135
    IrishRed
    Central PA
    Aaahhhhh.....smart and witty! A dual threat guy! Gonna have to keep my eye on you!
  16. Aug 3, 2021 at 1:54 PM
    #136
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Being that the sport model has a hood scoop it's highly capable off road.
    k_j_souv and poopshute like this.
  17. Aug 3, 2021 at 1:58 PM
    #137
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    As someone who has used the OR goodies to unfuck my truck, where do I post? What should I say?
    IrishRed likes this.
  18. Aug 3, 2021 at 1:58 PM
    #138
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    All that engine cooling!
    tacotoe likes this.
  19. Aug 3, 2021 at 2:06 PM
    #139
    Nirango kid
    Gilles
    Ontario
    Who said the TRD Sport was off road. It is not
  20. Aug 3, 2021 at 2:07 PM
    #140
    Slashaar
    Josh
    Kansas City, MO
    I beg to differ.
