How come sometimes my taco won't stop?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gt40, Apr 8, 2012.
  1. Apr 8, 2012 at 2:16 PM
    gt40
    gt40 [OP] Well-Known Member
    Georgia
    11 SR5 4X4 SB TOW PKG.
    Every once in a while my new 2011 Taco is very hard to stop. At least twice I have had to put all my 235 lbs. on the brake peddle to barely get it to stop before I would go through a red light. I have read that others have had this problem. I asked the dealer about this and I don't think they believed me. Has anyone had an accident because of this?
  2. Apr 8, 2012 at 2:19 PM
    bubbagumps
    bubbagumps Well-Known Member
    How fast were you going and in what distance did it take you to stop?
  3. Apr 8, 2012 at 2:19 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Did you get the Brake Booster checked?
  4. Apr 8, 2012 at 2:26 PM
    gt40
    Georgia
    Don't remember because I was trying to stop. I have read where other guys thought it was because of the ABS, but I don't think that is the problem.
    I have not had the Brake Booster checked yet. Probably tomorrow.
  5. Apr 8, 2012 at 4:59 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Leave it at the dealer until they fix it. Sounds like a boaster or vacuum leak. You can blame the ABS if you like every one else does.
  6. Apr 8, 2012 at 5:01 PM
    Noslow100
    Noslow100 Well-Known Member
    Josh
    VA
    08 SR5 4x4
    Toytec 3 Inch lift kit with Bilstein 5100's, and more
    does it have a spongy feel from time to time? Mine has a very soft feel almost every morning when I first drive it.
  7. Apr 8, 2012 at 5:02 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Are these hard fast stops? Do you feel pulsing in the pedal or a clicking feeling?
    Air in the lines will cause a mushy, poor braking experience.
  8. Apr 8, 2012 at 11:17 PM
    gt40
    Georgia
    Yes most of the time.
  9. Apr 8, 2012 at 11:23 PM
    logcabinwc
    logcabinwc Well-Known Member
    Micah
    SF East Bay
    08 4d 4x4 White V6 TRD
    Old Man Emu 885s with Nitrocharged 90000, Bilstein 5100 in the back with AllPro 3 spring progressive AAL, 16 inch Baja Black 6-spoke alloy wheels, Flow Master exhaust, bed lights, Pioneer HD radio, Uniden CB Radio, K&N Air filter, BAMF Sliders w/kickout, Relentless Aluminum IFS Skid, 24 LED light bar, custom/homebuilt expedition style bed rack and basket combo, and Body Armor rear plate bumper.
    if it has a spongy feel to it, could be the master cylinder. which could be very bad and need replacing asap. if it is just "sometimes" hard to press not quite sure....
    if you notice that to stop you have to press the pedal farther and farther down to stop, it could be the rotating "gear" that actually turns when you press the brake. This can be fixed by going in reverse or using you e-brake a lot more. or just going to the dealership and asking them to adjust it.
    btw, i just listened to the podcast car talk on npr today... and someone had this question and that is exactly what they said
    (yes im a 21 yr old who enjoys car talk on npr... hahaha)
  10. Apr 11, 2012 at 7:22 AM
    gt40
    Georgia
    Took my 2011 DC to the dealer yesterday morning. Wouldn't you figure when I started it up and was driving there the brakes felt like they should. No sponginess or other problems. Actually I had not noticed anything abnormal for the preceding few days.
    I guess it was like bringing your car to get a squeak fixed and when you get there it won't squeak.
    They checked the computer to see if it had any readings saying there was a problem and had none. They also checked for air someplace in the braking system and couldn't find any. Everything seemed like it should be.
    The service manager wrote up my observations of the problem in the Tacos records incase of future problems.
    What ever the problem it seems to have worked itself out. If the brakes stay the way they are now I will consider it perfect which has always been the case with all the other Toyotas I have bought. :):):):)
    PS: As for backing up and pressing the brake more I have changed the way I get into my garage which makes me back up a lot more and pressing the brake peddle while backing up. This may have fixed the problem?
  11. Apr 11, 2012 at 7:27 AM
    Large
    Large Red
    ^ Typical. Donna is the same damn way when I want my blower motor replaced, it don't make a squeal if its going to the dealer.
