How common is the 3.91 rear?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Clark, Sep 17, 2012.
  1. Sep 17, 2012 at 6:27 AM
    Clark
    Clark [OP] Active Member
    I'm looking at swapping the diff's (front and rear and actually, probably just the ring and pinion) in my Taco for a set of 3.91's. I've got a 2000 model and from what I understand, most Tacos, T-100s and some Tundras without the electric locker all use the same differentials. Any idea how common the 3.91 set is or what make/model year combo I'm most likely to find it in?
    Also, is there any danger in using a used ring and pinion from a different vehicle, assuming it passes an inspection?
    Clark
  2. Sep 17, 2012 at 4:36 PM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    This should help
  3. Sep 17, 2012 at 8:09 PM
    Clark
    I have seen the decoding tables for Toyotas and that is a huge asset when looking for one. I was more interested if there are many out there because I mostly hear of Tacos coming with 4.1, 4.3, 4.56, etc and very few are down in that 3.XX range. I hate to go looking for a set if they only exist as a code on a table!
    Clark
  4. Sep 17, 2012 at 8:41 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I had a Silverado with 4.10's that was nice and a Sierra with 3.73's that was terrible driving at highway speed. It wanted to shift on the slightest incline. I wouldn't go below 4.10's unless you stay below 70 mph. Just personally preference though.
  5. Sep 18, 2012 at 5:12 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    Manufacturers are pretty smart, they match the gearset to the engine. The reason you see so many 4:10, 4:56 gearsets in Toyotas is because they don't have much low end grunt(torque). Gearsets down in the 3's will give you more topend but will compromise towing and hill climbing. My old Buick electra had a 2:56 gearset but it had a 430 cu. in. torque monster that I once used to tow another car with a seized engine to try and unseize it, hardly noticed it behind me except for the squealing tires. I also took a look thru the local scrapyards and it seems every 1st gen sold up here had 4:10 gears so good luck.
  6. Sep 18, 2012 at 9:11 AM
    pippen
    pippen that was'nt a vitamin!!
    Pippen
    Eastern NC
    04 PreRunner Ext.
    Mine is 4.10 :(
  7. Sep 18, 2012 at 9:18 AM
    98tacoma27
    Ben
    Not Beech Creek
  8. Sep 18, 2012 at 10:04 AM
    kgw
    kgw Well-Known Member
    kgw
    SoCal
    99 PreRunner
    140 amp alternator, Big 3 upgrade, Ultimate Headlight Mod, Trans Cooler
    I really like the 4.10 in my PreRunner. . .Good acceleration, great hill-climbing, with the 3.4 V6.
  9. Sep 18, 2012 at 11:08 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yes i think this is right sort of..
    Most 3.4L manuals came with 4.10s as i understand it. Mostly just prerunners i thought came with th 3.90 gears.
    most 2.7l 4x4s manuals i believe came with 4.30s and if it was an auto with 4.56.
    again tho..i have no real way of confirming this, just what i have read and noticed talking to people..
  10. Sep 18, 2012 at 2:34 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    yep that's mine. Non trd I want something in the 4 range...31x10.5x15 tires don't like hills or acceleration.
  11. Sep 19, 2012 at 5:10 AM
    Clark
    Thanks 98taco27, that's the sort of thing I was looking for. Now, if only I could find information for other years!
    My '00 Taco is a manual, 2.7 and has the 4.3 gear set in it. Possibly, when they changed things in '01 they also changed that or mine is the oddball, tough to say.
    Clark
