How could I mount this in my truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ToyotaKTMracing, Jan 4, 2013.
  1. Jan 5, 2013 at 7:10 AM
    ToyotaKTMracing
    ToyotaKTMracing [OP] The Blue Warrior
    Shay
    West Virginia
    2008 DCSB Ink 4WD Auto
    285 BFG ATs, Custom dual exhaust system, 4" total lift (adjustable billies with 885 coils in front and AALs with 1" block in rear), interior LED lighting, LED reverse lights, LED license plate lights, fog light anytime mod, JVC KW-R500 stereo, 20" okledlightbars.com LED light bar, coverking seat covers
  2. Jan 5, 2013 at 7:26 AM
    Andres
    Andres Well-Known Member Vendor
    Andres
    Hawthorne, CA
    2013 Toyota Tacoma TRD off-road
    I'd help you machine a simple bracket if I weren't so darn busy all the time. :(
  3. Jan 5, 2013 at 7:30 AM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    If you're running an aftermarket bezel that you don't mind trimming, you can do what I did for my handheld GPS.
    Trimmed edge of Scoshe bezel-
    Fabbed piece of aluminum flat bar stock from Lowes-
    Rattlecanned black then stuck to back of bezel with 3M grey double-sticky-
    Mount double-stickied to aluminum bar-
    End result. Up where I can see and finger it, but not blocking my view or the vent-
    One thing I would recommend if you go this route is using 1/8" thick aluminum if there's any sort of weight to your scanner. I used 1/16" for this mount and will be redoing it with 1/8" before summer. While this works fine, it allows for too much vibration while driving which makes the screen difficult to see, especially when off-road which is my primary use here.
  4. Jan 5, 2013 at 8:12 AM
    ToyotaKTMracing
    Shay
    West Virginia
    I like that!
  5. Jan 5, 2013 at 8:12 AM
    ToyotaKTMracing
    Shay
    West Virginia
    It's fine. I'll figure something out. Thanks for the offer though :D
  6. Jan 5, 2013 at 6:48 PM
    ToyotaKTMracing
    Shay
    West Virginia
    I might do velcro and attatch it to the little black square piece by the stereo
  7. Jan 5, 2013 at 7:35 PM
    Andres
    Andres
    Hawthorne, CA
    X2
    Keeping it simply is sometimes the best way.
    I like the sheet metal bracket idea, it's not so bad working with sheet metal and relatively easy. = ]
  8. Jan 6, 2013 at 6:09 AM
    StickShifty
    StickShifty Well-Known Member
    New Jersey
    2012 AC 4WD 6SPD
    u ever think about a mobile scanner instead with a remote speaker? they are cheaper then the handhelds unless you get a PL scanner. I have one mounted under my passenger seat and a small remote speaker in between my rear seats. makes for a clean install and everything is out of the way.
  9. Jan 6, 2013 at 12:54 PM
    ToyotaKTMracing
    Shay
    West Virginia
  10. Jan 6, 2013 at 12:56 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    09 Access Cab V6 4X4
    Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Goodyear Wrangler Duratracs, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings,... oh and the hot wife mod.
    You can find these with adjustable holding sizes ..
  11. Jan 6, 2013 at 1:00 PM
    ToyotaKTMracing
    Shay
    West Virginia
    I know. I might get one. The one now is temporary
