How did you hard wire your dash cam?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Technical Ted, Jul 26, 2020.
  1. Jun 30, 2021 at 9:35 PM
    #41
    No_Smoking
    No_Smoking Active Member
    Oregon
    2021 TRD Pro
    Hey all, I took my dashcam game a step further when I bought the VIOFO A139 3CH and also the hardwire kit with an Add a Fuse.
    I got it all installed but had a question about the add a fuse wire.
    What determines the direction of the add a fuse wire overhang?
    For example, in this thread, the two photos show the wires go off, away from the OBD port. Mine is toward the port.. if I flip them the cam turns on with the truck, but off completely when the truck is off (parking mode on the cam was turned on.)
    In almost all the videos and pics I've seen, most of them the wires hang off to the left
    What am I missing?
  2. Jul 20, 2021 at 4:29 AM
    #42
    Technical Ted
    Technical Ted [OP] Well-Known Member
    Ted
    Western NY - Finger Lakes
    2020 Tacoma Limited Barcelona Red
    With the ones I bought, I had to use a meter to determine the hot terminal in the original receptical and the fused side in the add a fuse. If I plugged it in wrong, it wouldn't be using the fuse, just be hot all the time. If yours doesn't have directions (like mine didn't) check things out with a meter.
    Ted
  3. Sep 9, 2022 at 2:50 PM
    #43
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Is there any fuse in the cab fuse panel that's always hot and safe to tap? I have a switch panel off the open sunroof one, but the two I have now are ignition triggered. Hoping it's as easy as swapping to a different fuse to set it up for parking mode.
