How did you recalibrate your speedometer after larger tires?
Discussion in 'Wheels & Tires' started by geekhouse23, Jul 1, 2014.
  1. Jul 1, 2014 at 1:36 PM
    geekhouse23
    geekhouse23 [OP] The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I am going to be upgrading to 285 Duratracs very soon and I was wondering if anyone had any info on the Hypertech Speedometer Calibrator tool. I know the speedo will be off a bit after the change in tire diameter. This calibrator tool seems very simple and easy to use as it just take apart the dash cluster and plug it in.
    I have researched various threads, but I thought this could be a "mega-thread" of sorts.
    If anyone has any info on the Hypertech Speedometer Calibrator or if there are any other tools people like to use, please post here.
  2. Jul 1, 2014 at 1:40 PM
    la0d0g
    running for the hills
    For crawling not hauling
    I used a GPS to see how fast I was going at certain speeds. No I have reference points and can pretty much guesstimate where I'm at at any speed.
  3. Jul 1, 2014 at 1:44 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I installed the Hypertech speedometer calibrator. Works fine for me. 2011 "old style" speedo cluster. The first one they sent was no good and I had to have it replaced under warranty. However, I had to remove the instrument cluster - and plug it "in line" between the harness and the cluster. So the install is more involved than you suggest in your original post.
  4. Jul 2, 2014 at 1:22 PM
    geekhouse23
    FIFY :(
    Contacted AutoAnything and Hypertech and they both confirmed that the original person I spoke with at AutoAnything was wrong. I will have to take apart the gauge cluster and do it that way. Not sure why they won't make an ODBII port programmer :notsure:
    I think I might just bite the bullet and purchase it. Their deal is $25OFF 199.99 or more plus free shipping.
    Any other suggestions?
  5. Jul 2, 2014 at 2:16 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I haven't really dug into it but I think the root cause is something like that Toyota encrypts all their ROMs to prevent hacking aftermarket chip programmer tools.
  6. Jul 3, 2014 at 7:41 AM
    geekhouse23
    That really sucks :pout:
    I went ahead and bought it anyways. Used a coupon code for AutoAnything and got $40 OFF with free shipping. Hope I made a good choice :eek:
  7. Jul 3, 2014 at 7:49 AM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Should have waited some people have found their speedos to be more accurate with the larger tires. Mine was only off by 3 mph after I went to 33's. No clue how it happened but it did.
  8. Jul 3, 2014 at 8:28 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    But, officer! :D
  9. Jul 3, 2014 at 8:32 AM
    poundin tacos
    poundin tacos Well-Known Member
    Scot
    Dallas, TX/ SFL
    2021 TRD Off-Road, 2018 built Macan Turbo (daily), 2nd gen dodge, 89 944
    First I figured out the weight difference and subtracted the surface area of the old tire from the SA of the new ones, then I didn't. I just guess.
  10. Jul 3, 2014 at 8:36 AM
    Indy
    Indy Master of all I survey.
    Your speed will always be off by a % not a set number. If you are off by 3mph at 20 youll be off by a lot more at 70.
    With 235s mine was off by about 10%, went with 31s and im off in the other direction about 5.
  11. Jul 3, 2014 at 8:38 AM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Mine was showing according to gps at 65 mph on the speedo my gps showed 67-68
