How did you run antenna coax to cab?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Baby, Feb 25, 2021.
  1. Feb 25, 2021 at 5:20 PM
    Baby
    Baby [OP] Well-Known Member
    Northern, CA
    03 Tacoma 3.4
    I am mounting an antenna on the hood and wonder how you guys with ham/cb ran your coax into the cab. I searched and saw threads about running cable through the grommet where the main fuse box is, but my coax is already built up with ends, and that grommet looks too tight. The one under the cab, on the driver side rail looks like a possibility. What have you done or seen?
    Darrell942 likes this.
  2. Feb 25, 2021 at 5:22 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    If it’s anything like running a wire for an aftermarket backup camera, look up “Greenlee snake”; Absolutely ingenious tool!
    Baby[QUOTED][OP] likes this.
  3. Feb 25, 2021 at 6:21 PM
    Baby
    Northern, CA
    03 Tacoma 3.4
    I think I'm going to have to pull the grommet in the firewall and cut a slit in it. With the grommet removed, I should be able to push the factory wires aside more easily to push the connector through. Then I can pull the coax through, reinstall the grommet, and spooge it all up so it doesn't let water in. I'll have to run power through there as well, but those wires are pretty thin.
  4. Feb 25, 2021 at 6:23 PM
    Sand Dog
    Sand Dog Well-Known Member
    2018 SR, 4x4 DCSB MGM
    Aluminum brake line cut on a diagonal.
    Baby[OP] likes this.
  5. Feb 25, 2021 at 6:24 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Taco critter likes this.
  6. Feb 25, 2021 at 7:35 PM
    Baby
    Northern, CA
    03 Tacoma 3.4
    That's good to hear! Thanks!
  7. Feb 25, 2021 at 7:56 PM
    Baby
    Northern, CA
    03 Tacoma 3.4
