how do adjust the rear brake pads
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JakeMan, Sep 9, 2010.
  1. Sep 9, 2010 at 3:58 PM
    JakeMan
    JakeMan [OP] Alfred E. Neuman
    san francisco
    06 Prerunner
    jba headers-K&N intake-urd shortshifter
    ok so i wanted to change the rear pads and adjusted the star wheel. after i did that i had the idea to look inside and removed one of the rubber gramotts and the pads look fine. now the parking brake travels more than normal. how do i readjust the rear pads. i know what your thinking can't teach stupid... but can some one help
  2. Sep 9, 2010 at 4:24 PM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    Sure you didnt turn the adjustment wheel the wrong way? It should have slight resistance when turning the rear drum.
  3. Sep 9, 2010 at 6:12 PM
    JakeMan
    san francisco
    06 Prerunner
    i didn't remove the drum
    and the star wheel seams to only turn in one direction
  4. Sep 9, 2010 at 6:19 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    how to remove drum
    alternate bolts untill drum comes off
  5. Sep 9, 2010 at 6:21 PM
    JakeMan
    san francisco
    06 Prerunner
    can you adjust the brakes with out removing the drum
  6. Sep 9, 2010 at 8:18 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Yes, that's what the star wheel accessed through the hole in the back is for. It turns only one way from there which is to tighten them. To loosen them using the star, you have to push in and hold a little level that keeps it from turning the wrong way and loosening them (which is a PITA from the back due to limited space, but it's sometimes necessary to get the drum off if the shoes have worn down a deep channel in the drums). Once you get a little resistance in turning the wheel, you're good. Then pump the e-brake a few times.
