How do aftermarket tonneau covers compare to OEM?
Discussion in 'Tonneau Covers, Caps and Shells' started by ocal780, Sep 22, 2019.
  1. Sep 22, 2019 at 8:09 PM
    ocal780
    ocal780 [OP] New Member
    California
    Hello,
    How do the aftermarket tonneau covers compare to the OEM one?
  2. Sep 22, 2019 at 8:18 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Personally I think the Oem is junk
  3. Sep 22, 2019 at 8:52 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Are you looking for opinions on trifolds?
    ocal780[QUOTED][OP] likes this.
  4. Sep 22, 2019 at 8:59 PM
    ocal780
    California
    jake72--Any aftermarket brands you recommend?
    Vlady--Yes looking at trifolds.
  5. Sep 22, 2019 at 9:03 PM
    Bishop84
    Bishop84 Well-Known Member
    OEM has the best fit and finish. I've installed many.
    Best aftermarket is the bakflip mx4.
  6. Sep 22, 2019 at 9:05 PM
    rascott95
    rascott95 Well-Known Member
    Dallas, TX
    2019 DCSB TRD Off Road
    I’ve had good luck with the Bakflip G2. Aftermarket tri folds also don’t require messing with the rail system to install, which I believe is required for the OEM cover.
    ocal780[OP] likes this.
  7. Sep 22, 2019 at 9:18 PM
    sxe4533
    sxe4533 Well-Known Member
    Edmond, OK
    2016 TRDORDCSBAT
    2015 TRD PRO suspension
    I v had the backflip fibermax for over 3 years no issues. Color fades a bit, leaks a bit on the sides that’s due to the bed rails not being flat. I believe any cover will have this same issue but my stuff never got wet.
  8. Sep 23, 2019 at 3:44 AM
    jake72
    Jake
    N.E. PA
    Your right about the oem, does fit almost perfect with only the 2 very small holes at the front. They can be easily sealed with silicone, cover itself just seems kind of cheap made.
    ocal780[OP] and MannyS like this.
  9. Sep 23, 2019 at 4:03 AM
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    OEM means you have to cut the top rail covers...that's bullshit.
    4 panel tonneau is better than 3 panel. Easy access to front or rear of bed. Watch the installation video on a Tacoma
    https://youtu.be/S6RgFPg6sFs
  10. Sep 23, 2019 at 4:13 AM
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
  11. Sep 23, 2019 at 4:18 AM
    TacoSmurf
    TacoSmurf Active Member
    2017 Tacoma SR5
    I have the Gator Evo (now it’s called Gator EFX) and have nothing but positive things to say about it. Very easy to install, it’s aluminum so it’s light weight, easy to remove when needed, and keeps a nice tight seal. Also I prefer the clean/low profile look it provides over the bed.
  12. Sep 23, 2019 at 4:36 AM
    hfjeff
    hfjeff Well-Known Member
    Frozen Tundra
    2021 Army Green Off Road
    I am returning this one to Amazon as I could not get it to fit/seal well.
    The seals on the bottom of this cover are rock hard rubber which I believe is the biggest to blame. Also 1 of my hinges did not open all the way and raises the middle panel up just a bit. And with the front bulkhead of the bed sitting higher than the bed sides, this also added to a large gap near the front of the cover as it ramped up in the front.
    Then there are the latches. There are a lot of moving pieces and they are quite flimsy. The rear let loose on me and when I got home they were just dangling-not attached to anything. Lucky I did not lose the entire thing on the highway at 70mph.
    I had an ExTang v1 on my Ram and loved it. The seals were softer and molded to the top of the bed and front rail nicely. The latches were much more sturdy and durable and spring loaded so they always kept down pressure on the cover. However the cost now is significantly higher than what I paid a mere 5 years ago and they are all plastic rather than aluminum.
    I ordered the Agri-Cover LoMax from Truck Alterations and it should be here this week. Good luck with the Tyger. Maybe you will have better luck than I did.
    ocal780[OP], Rockoma5 and Beauxdon like this.
  13. Sep 23, 2019 at 5:25 AM
    jake72
    Jake
    N.E. PA
    I like the truxedo lo pro lq, it's a roll up cover. Built to last the life of your truck, and can be removed in less than a minute.
  14. Sep 23, 2019 at 5:55 AM
    Beauxdon
    Beauxdon TTC #289
    Houston, Tx
    2010 TRD Sport DCSB
    OOH nice. Excited to see your thoughts on this. I was about to pull the trigger on the soft fold, but if this is legit I am in
    Bad batch maybe?? I hope it was just a flimsy one, I'd like to buy a decent hard trifold for less than $800
    ocal780[OP] and rascott95 like this.
  15. Sep 23, 2019 at 6:04 AM
    Beauxdon
    Beauxdon TTC #289
    Houston, Tx
    2010 TRD Sport DCSB
    Did this use the factory rails or did you have to relocate?
  16. Sep 23, 2019 at 6:37 AM
    rascott95
    Dallas, TX
    You’ll have to post a review when you get this in. It seems like a heck of a deal if it works well.
  17. Sep 23, 2019 at 6:58 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
  18. Sep 23, 2019 at 7:54 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Yes. The handle itself was made of thicker, tougher plastic with grippy ribbing (yeah yeah sounds weird).
    Here's the older style:
    The new handles are made of thin, more flexible tubing. It feels flimsy IMO:
  19. Sep 23, 2019 at 8:05 AM
    DanoT
    DanoT Well-Known Member
    Victoria, B.C in summer. Sun Peaks, B.C. in winter
    2019 TRD 4X4 AC OR 6M/T
    My BakFlip MX4 was less expensive than Toyota OEM. BakFlip folds up to a vertical position giving access to all but 3'' of the open bed in this position. The Toyota OEM must be completely removed to gain full access to the open bed...and them what do you do with it and where do you put it?
    Frsh2df, ocal780[OP] and Speedfreak like this.
  20. Sep 23, 2019 at 8:08 AM
    CurtisF
    CurtisF Well-Known Member
    Curtis
    2019 Tacoma Off-Road
    None
    I went with a Bakflip MX4 due to its flush with top of bed look and the fact its a true tri-fold (some only fold twice) so you can use the whole bed ... after i decided that's what I wanted I also happen to come across it on Craigslist.
    lynyrd3, Seth2197, hfjeff and 3 others like this.
