How do aftermarket tonneau covers compare to OEM?
Discussion in 'Tonneau Covers, Caps and Shells' started by ocal780, Sep 22, 2019.
  1. Sep 23, 2019 at 8:10 AM
    TacoSmurf
    TacoSmurf Active Member
    2017 Tacoma SR5
    Yes it utilizes the existing bed rails...This system comes with two rails that you have to attach to the existing rails. Super easy to install, with just 3 bolts on each side. No drilling at all. With that being said, if you’re wanting to use those bed rail cleats, you won’t be able to with this Gator cover. Unless you remove the entire tonneau system.
    In my opinion its the best bang for the buck. Yes, there are others that are superior (Extang, Bakflip) but for my needs the Gator was perfect. And half the price might I add.
    All depends on your preferences/needs and how much you’re willing to spend. The Gator cover itself is also completely removable in under 30 seconds if you need to utilize the entire bed. Hope this helps. :thumbsup:
    ocal780[OP], Tallman44 and Beauxdon like this.
  2. Sep 23, 2019 at 9:08 AM
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    Will do. I couldn’t find any reviews of it anywhere, but ordered it directly from Amazon so return would be no hassle if it doesn’t work out. The reviews on the tyger soft version are overall really positive, so hopefully the poster above that is returning just got a bad one. Hopefully get a decent one. I’m guessing with harder seal material the gaskets will last longer but will require more force to get them to do the job. I don’t think any of them seal perfectly without some effort just due to the design of the top rail. I’d expect them to leak a little in a car wash, but remain relatively dry driving in a rain storm. That’s all I need, don’t need em air tight or anything. Should be here Wed, probably get around to those and installing running boards by the weekend.
  3. Sep 23, 2019 at 9:19 AM
    rascott95
    rascott95 Well-Known Member
    Dallas, TX
    2019 DCSB TRD Off Road
    Hopefully so. I am with you on that one, I don't need anything waterproof or air tight. Water resistant would certainly do the trick, especially on a $500 cover.
  4. Sep 23, 2019 at 9:26 AM
    Black taco.
    Black taco. Well-Known Member
    4x4. MT.
    OEM.
    ocal780[OP] likes this.
  5. Sep 23, 2019 at 9:45 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I went with the MX4 as well. Great match for the truck. More access to the box when open than the Trifold versions. The flush fit is nicer IMO and if you need to remove it, 2 bolts at the front and off it comes.
  6. Sep 23, 2019 at 9:48 AM
    Tallman44
    Tallman44 Active Member
    2019 TRD 4x4 off road long box
    I just ordered the Gator EFX. I figured if i needed the full bed, I would just remove the cover all together. For $400 less than the MX4, i didn't see much value and leaning the cover against by back window.
    ocal780[OP], TacoSmurf and CusterFan like this.
  7. Sep 23, 2019 at 10:13 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I have this one and really like it. IMO its the best looking cover out there. Has some small leaks in heavy rain but nothing that concerns me (mostly from the bed itself). Can remove it in less than a minute. Email them and you can get it well under 800.
    http://www.truckalterations.com/LOM...TYLE%7C60.5%20in.%2F5%20ft.%200.5%20in.%20Bed
  8. Sep 23, 2019 at 10:28 AM
    aleja_333
    aleja_333 Well-Known Member
    Colorado
    19’ Pro AT, 5.29's, Fox 2.5 RR, Alcan, PowerBrake
    Magnuson, Stryker tune, C4, Archive Garage HH, Alucab CC
    I recommend Diamondback Covers. They look awesome and are tough to handle anything you throw at them.
  9. Sep 23, 2019 at 12:30 PM
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    I bought this cover and it is supposed to be here Thursday. I like that this one uses strikers to latch it and that the front panel can be opened independently allowing access to the area in the front of the bed without having to fold the whole thing up. It seems to be a very secure design. I may have to wait a bit to install it because someone hit my truck in the parking lot at work with a roached out Honda Odyssey. It's going to the body shop today. 1400 miles on it...At least she had insurance.
  10. Sep 23, 2019 at 12:37 PM
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    I’m super happy with my Tyger soft rollup. Less than $200. You could buy a new one every 2 years, and spend less than some of the hard or tri-fold models. And, a rollup is the only option which provides 100% bed access plus rear vision. I know people worry about security, but it’s probably just as easy to pop open some of the hard covers as to cut a soft cover.
  11. Sep 23, 2019 at 1:01 PM
    Wesconsin
    Wesconsin Member
    Wisconsin
  12. Sep 23, 2019 at 2:03 PM
    hfjeff
    hfjeff Well-Known Member
    Frozen Tundra
    2021 Army Green Off Road
    Having lots of experience with the ExTang V1 and now the Tyger T5, I was going to try to retro-fit ExTang rear clamps onto the Tyger T5 as they appear to latch pretty solid in the Tacoma side rails. But I decided to draw the line and purchase the cover I really wanted instead. For anyone interested, I think you could remove the flimsy rear Tyger clamps and use eye-bolts to fasten the ExTang clamps.
  13. Sep 23, 2019 at 2:55 PM
    DanoT
    DanoT Well-Known Member
    Victoria, B.C in summer. Sun Peaks, B.C. in winter
    2019 TRD 4X4 AC OR 6M/T
    The Bakflip mX4 when in vertical folded up position does not lean against the back window as it is held upright by two rods that are tightened in place by hand turned knobs allowing operation at highway speeds. The middle cab mounted brake light also remains functional and so do those bed rail sliding knobby things.
    Yann and Tallman44[QUOTED] like this.
  14. Sep 23, 2019 at 2:56 PM
    Winch
    Winch Well-Known Member
    2019 TRD OR MT V6
    None yet
    I have the Extang 2.0 solid trifold. I had to have the front panel replaced under warranty because it developed divots where the clamps are located. Now the replacement panel is starting to do the same thing.
  15. Sep 23, 2019 at 4:04 PM
    #35
    ocal780
    ocal780 [OP] New Member
    California
    I appreciate all the feedback, will let you guys know which I one get, thanks!
    CusterFan and Bishop84 like this.
  16. Sep 24, 2019 at 7:09 PM
    #36
    hfjeff
    Frozen Tundra
    The LoMax arrived today and is installed. I am very fussy and happy with this new cover.
    nelmed585, ocal780[OP] and Beauxdon like this.
  17. Sep 24, 2019 at 7:56 PM
    #37
    Sandlyfe73
    Sandlyfe73 Well-Known Member
    Vegas / Henderson
    2017 TRD SPT
    That’s a clean looking lid. Nice job
  18. Sep 24, 2019 at 8:47 PM
    #38
    TRDProOne
    TRDProOne Well-Known Member
    CA
    2019 TRD Pro in Super White
    Just ordered my Lomax bed cover today. It’s the exact same cover that’s sold by WeatherTech. $675 shipped to my door.
    hfjeff and KY_Rob like this.
  19. Sep 24, 2019 at 10:05 PM
    #39
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    I'm'a get me an Undercover Ridgelander.
    CusterFan likes this.
  20. Sep 25, 2019 at 5:59 AM
    #40
    TRDProOne
    CA
    Have you looked at the DiamondBack cover? The price point is about the same and nothing but good reviews.
