How do Check Engine codes clear?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ztwatson, Mar 14, 2023.
  1. Mar 14, 2023 at 7:29 PM
    ztwatson
    ztwatson [OP] Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    I've been having a P0446 code check engine light hang with me for a while. I've tried the new gas cap and new vacuum lines. Both times I disconnected the battery for a bit and the check engine light came back on within the first drive (pretty sure first drive? definitely wasn't gone long). I did have to reset my clock and stereo so I figured I should've given enough time to clear the codes/memory as well. I recently replaced my UCA's and had my battery removed for about and hour. Once everything was back together the check engine light was off. I've driven the truck close to 700 miles now. Probably fired it up at least 20-30 times since. Check engine light still off. So I guess my question is did I just not give the ECU enough time to clear its memory when I did both of those fixes? Would really love to believe this code is gone.
  2. Mar 14, 2023 at 8:53 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    EVAP codes take the longest to set/reset. If you cleared it, I've heard of cases where it can take up to a couple thousand miles to reset. Highway miles are best.
    Area51Runner likes this.
  3. Mar 14, 2023 at 10:39 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Depends your bit might have not been long enough ! I saw any time between 30 seconds and 10 minutes go figure
    Time to get a simple code reader that will clear the PO codes easier then disconnecting the battery.
    For me anyhow.
  4. Mar 16, 2023 at 6:32 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    I feel your disdain for the EVAP codes. So many vacuum lines and possibilities to chase down. If it's gone - just ignore it for now :)
