How do I adjust the coilovers
Discussion in 'Suspension' started by iJDub, Jul 12, 2013.
  1. Jul 12, 2013 at 3:22 PM
    iJDub
    iJDub [OP] Well-Known Member
    I have Icon extended coils and about to put it on. How do I get them set to 2.5" before I get them out on my truck?
  2. Jul 12, 2013 at 3:34 PM
    munkel
    munkel fka unregistered lurker...
    PDX
    2004 Dbl Cab V6 4WD Tacoma
    Icon Suspension, 285/75/16 BFG MT's, Steeeckers, Custom Bed Mounted Tool Storage, Wilderness Trail rack, SoftTopper, K&N CAI, Hella Aux lights, PIAA Fogs, Warn M8000, Elite Front Bumper, BAMF sliders, All-Pro leafs and shackles
    You don't, you'll need to put them on and then adjust. Factors such as aftermarket bumpers etc prevent these from being something you could set beforehand. Everyone's rig is different. That said they should have come from Icon set for about 2 inches I think.....
  3. Jul 12, 2013 at 3:52 PM
    iJDub
    I was told not to adjust it while it's on the truck due to twisting it against tie rod?
    I'll need to get another alignment too right?
  4. Jul 12, 2013 at 4:16 PM
    munkel
    PDX
    I can only speak to mine but I adjust them all the time on my 2004. I "may" be doing it wrong but I have had no problems yet.... I got an initial alignment after installing and setting height, since then I have not and have tweaked it a bit after a bumper install, winch etc.
  5. Jul 12, 2013 at 4:23 PM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    Adjust them on the truck . Nothing is going to happen to your tierods .
    Pretty sure they come set at 2.5 "
  6. Jul 12, 2013 at 4:26 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Will be a touch easier if you droop out your suspension AND then try to adjust...otherwise you're adjusting against the weight of the truck lol ;D
    So...jack up the front of your truck until the wheels are pretty much off the ground
  7. Jul 12, 2013 at 4:30 PM
    iJDub
    Ah OK. Thanks. Is there markings on it to make each side even or do I just measure fender to hub and turn each side so it's same length?
  8. Jul 12, 2013 at 4:32 PM
    munkel
    PDX
    No marking other than thread count, assuming they both come set to the same spot then crank them down the same amount on each side then measure for difference fender to hub.
  9. Jul 12, 2013 at 4:33 PM
    VolcomTacoma
    Jeff
    NorCal
    Its gonna be different on each side. Remember, your battery, fuel tank AND YOU are on the drivers side...so thats alot of weight...I would crank them up so your hub/fender measurements are level, then give the driver side another half turn or so
  10. Jul 12, 2013 at 4:35 PM
    munkel
    PDX
    Use the allen head set screw as your mark when cranking, every time you see it it has been one full revolution etc. Also make sure and loosen before cranking them down and then re-tighten that allen.
