How do I align the differential with the driveshaft 2017
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Eric5456, Nov 5, 2020.
  1. Nov 5, 2020 at 1:29 PM
    Eric5456
    Eric5456 [OP] Active Member
    2017 Tacoma trd sport 2x4
    How do I align the differential with driveshaft on 2017
  2. Nov 5, 2020 at 2:14 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    I’m not sure about the Tacoma’s but I know that the drive shaft isn’t always centered on some trucks
  3. Nov 5, 2020 at 2:17 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    what mods have U done to Ur truck
    how many miles
    are U referring to the degree/angle of the diff to the transfer case??
  4. Nov 5, 2020 at 2:20 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Clarify please...
    The way I read it, you want zero working angle at the pinion...that's a bad idea.
  5. Nov 5, 2020 at 2:21 PM
    Bishop84
    Bishop84 Well-Known Member
    Honestly? I just place the carrier it where it "relaxes" and theres no strain on level ground. Don't overthink it.
  6. Nov 5, 2020 at 3:12 PM
    Eric5456
    Leveling kit 2” rear and 3” in front and I’m reffering to the angle because when I installed the leveling kit the rear wheels locked up and the transfer case moved down slightly and it’s not straight with the driveshaft
  7. Nov 5, 2020 at 3:16 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Rule of thumb; add 1 degree of angle for each inch of rear lift.
    Did you change your leaf springs? “Adjust” the U-bolts? Explain what you did.
  8. Nov 5, 2020 at 3:30 PM
    Eric5456
    I have stock leaf springs and how do you adjust the u bolts do you just loosen them or tighten them
  9. Nov 5, 2020 at 4:06 PM
    splitbolt
    NW Arkansas
    Is the locked up rear wheels the actual problem? No vibes?
    Your parking cable is probably stretched.
  10. Nov 5, 2020 at 4:53 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    This is what it sounds like in his other/similar post,,, he mentioned the brake lever was harder to pull
  11. Nov 5, 2020 at 4:59 PM
    Eric5456
    Aha figured it out when I installed the leveling kit for the rear I put the tall side facing towards the front and the short side facing back so ima rotate 180 degrees and see what happens
