How do I change a blinker flasher
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dave 4100, Oct 22, 2016.
  1. Oct 22, 2016 at 2:56 PM
    Dave 4100
    Dave 4100 [OP] New Member
    Dave
    2010. Tacoma
    I have a 2010 Tacoma and installed LED lights and need to replace the flasher relay. Is there an easy way to do this?
  2. Oct 22, 2016 at 2:59 PM
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    You need to drill into the bottom of your blinker, drain the old fluid. Then put in the new
  3. Oct 22, 2016 at 3:01 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    very carefully
  4. Oct 22, 2016 at 3:11 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Great question... thanks for asking! The easiest way to do it is left handed while standing straight with knees slightly bent.
    T4RFTMFW likes this.
