HOW DO I CONVERT MY HALO HEADLIGHTS TO HID's
Discussion in 'Lighting' started by ZestysTaco, Sep 22, 2010.
  1. Sep 22, 2010 at 12:45 AM
    ZestysTaco
    ZestysTaco [OP] Member
    Zach
    orange county
    06 Silver Prerunner lifted
    6'' pro comp lift, 35'' nitto all terrain tires, k&n intake, valve body upgrade on transmission, gibson performance exhaust, halo headlights
    I want to convert my halo headlights into HID's. they are running an H1 bulb right now, how would i change it so that it will run HID's? please let me know, thanks
  2. Sep 22, 2010 at 1:09 AM
    dagul
    dagul Well-Known Member
    SoCal
    01 RR SR
    Shop around for a HID kit with H1 based bulbs...
    Example: link
  3. Sep 22, 2010 at 1:19 AM
    ZestysTaco
    Zach
    orange county
    so after i get an hid kit with h1 bulbs i should be able to run them?
  4. Sep 22, 2010 at 1:34 AM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    ya most hid kits are plug n play
  5. Sep 22, 2010 at 1:38 AM
    dagul
    SoCal
    01 RR SR
    You should be able to replace the bulbs with the H1 based HID bulbs, wire up the ballasts and be good to go from there... However light output will be kinda sketch and glare will be an issue...
    I'm more biased towards doing a retrofit, but that's a whole other ballgame...
    If you're willing to go back to a stock style headlight housing, something like this will give you pretty good light output with minimal glare...
  6. Sep 22, 2010 at 1:40 AM
    Surfbohica
    Surfbohica Mr. SR5
    Ben
    Kailua, HI (Tucson, AZ/ SanDiego,CA)
    05 DBL Cab SR5 Speedway Blue TRD OffRoad
    Bull bar, 2.5" front level lift, 10' color matching grill, black housing headlights, HIDs, in dash double din DVD player,
    Yeah I have halo headlights, and I just installed H1 HIDs
  7. Sep 22, 2010 at 1:48 AM
    ZestysTaco
    Zach
    orange county
    did you just use the h1 conversion?? is everythin runnin smooth? any problems?
  8. Sep 22, 2010 at 1:58 AM
    Surfbohica
    Surfbohica Mr. SR5
    Ben
    No its been in over a year and a half no problems, just plug and play
  9. Sep 22, 2010 at 2:12 AM
    ZestysTaco
    Zach
    orange county
    awesome man, thanks i appreciate it
  10. Sep 22, 2010 at 2:29 AM
    Surfbohica
    Surfbohica Mr. SR5
    Ben
    no worries! i needed to mod at all
