How do I correct bad cv angles
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sorgon82, Jun 20, 2018.
  1. Jun 21, 2018 at 10:05 AM
    #41
    Clearwater Bill
    Billy
    Largo Florida
    If you disassemble to remove spacers, or just want to try something......
    Either leave all the artiulating points with bushings loose, or loosen them. Any you had apart.
    Put the truck on the ground. Bounce the corners a few times. Drive it back and forth in the drive a couple of times, tapping brakes enough to give it some bounce.
    Then torque all those points while in compression.
    If nothing else you'll prolong the life of all those bushings.
    sorgon82[OP] likes this.
  2. Jun 21, 2018 at 11:02 AM
    #42
    ChoyotaIII
    ChoyotaIII Someone took "Choyota"
    Echo
    Placentia, CA
    2012 Spruce Mica + 2018 MGM
    Opinions on this angle? Hearing wildly different opinions on diff drops and whether they mean anything at all. Stock shocks, waiting for some aftermarket ones coming in. Currently on 1.5" strut spacers.
    Passenger Side
    Driver's Side
  3. Jun 21, 2018 at 11:45 AM
    #43
    eon_blue
    Azusa, CA
    outer boots look good but your inners are rubbing fins. In this case you might be good doing the boot slide mod on the inner boots.
  4. Jun 22, 2018 at 7:13 AM
    #44
    sorgon82
    sorgon82 [OP] wanna go for a rip bud
    Ont. Canada
    2016 Grey Tacoma sport dc long bed
    The front sits as high as the rear with hd dakars. I dont think I wanna wait to see how much it settles, ill prolly blow the cv by then..I think im going to do a few things while the fronts apart again.
    1st take the the 1/2" spacer out the driver side and put the 1/4" thats on the passanger side in there
    2nd put the ecgs bushing in
    3rd prolly take that dif drop out
    4th losen upper and lower control arms and torque them after level ground bounce
    HOPEFULLY by then i have normal 887 cv angles with no vibes20180621_180727.jpg
    scottalot likes this.
  5. Jun 22, 2018 at 8:04 AM
    #45
    sorgon82
    Ont. Canada
    Ya i think so. I just got greedy but pretty sure the 887 alone with dakars will sit nice with a bit of rake. And hopefully my angles get better
    scottalot[QUOTED] likes this.
  6. Jun 22, 2018 at 8:56 AM
    #46
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    I have a 1" drop netting 1/2" diff drop at the CV's. Have wheeled pretty hard at various angles up to 60 degrees with no issues. A lot of people make thoughtful claims but I've never seen actual proof of failure due to diff drop. Have you seen or read any failures? Only case i've seen was someone racing 60+ mph with a modified skid plate to allow diff drop and got caught and ripped the mount off.
    na8rboy likes this.
  7. Jun 22, 2018 at 9:03 AM
    #47
    sorgon82
    Ont. Canada
    How much lift are you running?
    did you drop it that much because your cv angles and did it correct it?
  8. Jun 22, 2018 at 9:24 AM
    #48
    TacoRD16
    Houston, TX
    I'm running 3" and my angles are pretty flat. I'll take a picture after work. I also run full skids plates that are designed for 1" drop.
    The rule of thumb is you don't want the ribs to be touching when it sits leveled. But then again alot people run 3" without diff drops and unless you are wheel it hard... wheels at full droop with quiet a bit of power or jolting motions going through the CV you shouldn't have any real issues.
    sorgon82[QUOTED][OP] likes this.
  9. Jun 22, 2018 at 9:38 AM
    #49
    eon_blue
    Azusa, CA
    I meant an increased diff drop like 3in. or more (sounds crazy but I've seen some really gnarly diff drops). Some people just keep stacking 1" washers.
    1" is the standard diff drop, that's what I have in too. I didn't notice much change at all with my angles when I did it. It helped the inner boots the most but my outers didn't get affected much.
  10. Jun 25, 2018 at 9:14 AM
    #50
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    This the one you are referring to?
    https://www.tacomaworld.com/threads/remove-the-differential-drop-on-your-05-tacoma.118545/
    And the math on diff drops:
    https://www.tacomaworld.com/threads/cv-angles.230749/#post-5432474
