How do I disable my Daytime Running Lights??
Discussion in '1st Gen. Tacomas (1995-2004)' started by 00YotaComa, Oct 8, 2009.
  1. Oct 8, 2009 at 1:19 PM
    00YotaComa
    00YotaComa [OP] HAWAII SELLS MORE TACOMAS THAN ANY OTHER STATE!
    Jack
    Big Island, Hawaii
    00 Tacoma SR5 TRD OFF ROAD
    1in. leveling kit, Deck plate mod, grey wire mod, K&N Filter , custom paint, Cyron LED lighting, head and tail blackouts
    I've tried disconnecting the D.R.L. fuse which Toyota suggested and did not work...help please. I have a 1st Gen. 2000 Tanx a lot!
  2. Oct 8, 2009 at 1:25 PM
    warpwr
    warpwr Junior Senior Member
    Vaughn
    S.F. Bay Area
    09 Sport Access Cab
    DRL mod with switch, rear spring TSB, trans TSB, tailgate mod, snug-top shell.
  3. Oct 8, 2009 at 2:03 PM
    00YotaComa
    Jack
    Big Island, Hawaii
    Thanks anyway!:D
  4. Oct 10, 2009 at 10:12 PM
    trailinTaco
    trailinTaco Well-Known Member
    Bel Air, MD
    2000 Tacoma SR5 TRD 3.4L 4x4
    3 inch suspension lift, 33 inch bfgoodrich mud terrain tires, toytech diff drop, Procomp alloy wheels, hella fog lights, black projector headlights with 8000k HID's, blacked out tail lights, two 12 inch subs, 20% tint, pioneer head unit and speakers
    sorry for being long but if your still looking for this here it is. i did it on mine
    ELECTRICAL
    EL011-00
    October 6, 2000
    Title:
    DAYTIME RUNNING LIGHT DISABLING PROCEDURE
    Models:
    All Models
    Introduction
    Some customers may request to have the Daytime Running Lights (DRL) on their Toyota vehicle disabled. These customers may live or work in military bases or in communities that have light-sensitive gates or guardhouses. This bulletin provides instructions for disabling the feature on the Toyota vehicles listed below. If the Daytime Running Lights (DRL) have been previously disabled, the information in this bulletin can be used to enable the feature at the request of the customer.
    IMPORTANT :please be sure the customer is informed that when the Daytime Running Lights (DRL) are being disabled, although it is not required by the Federal Motor Vehicle Safety Standards for safety compliance, it has been listed as a safety feature in advertising brochures. In addition, on models equipped with the Twilight Sentinel feature, the headlights will be defaulted to a manual system and will no longer function automatically.
    Applicable Vehicles ^All Models equipped with Daytime Running Lights (DRL) (see chart).
    Parts Information
    NOTE :After referencing the chart, proceed to the repair procedure.
    Warranty Information
    Repair Procedure
    1.Disconnect the Battery.
    2.Use the locking pick tool from the wire harness repair kit and back out the terminal from the appropriate connector for the DRL Relay or Body ECU. See the Reference Chart as shown in this bulletin for pin and connector information.
    3.Insulate the removed terminal using vinyl electrical tape.
    4.Secure the wire and terminal to the outside of the wire harness using vinyl electrical tape.
  5. Oct 10, 2009 at 10:14 PM
    trailinTaco
    Bel Air, MD
    oh and its pin 2 of the drl connector
  6. Oct 11, 2009 at 9:32 AM
    spp
    spp OC, Kalifornia
    OC California
    Sure wish the pictures showed up.......
  7. Oct 11, 2009 at 11:34 AM
    trailinTaco
    Bel Air, MD
    oh sorry here it is and this box is just above the emergency brake handle. just remove pin 2
