How do I eliminate the seatbelt beep?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by seaNOmercy, Mar 16, 2009.
  1. Mar 16, 2009 at 5:43 PM
    seaNOmercy
    seaNOmercy [OP] Member
    09 TRD Magnetic Gray
    2.5 inch leveling kit, all-weather mats, hood protector
    hey whatsup people?!
    this is my first post aside from my introduction.. I couldn't find the answer to this so far so i figured I'd just ask again, as I'm sure alot of other people are wondering the same thing.. Does anyone know off hand how to eliminate the seatbelt beeping noise! I understand that it's for my safety and I wear my seatbelt everytime I get in my truck, but alot of times I put it on after I put my truck in drive and it beeps a few times in between which is AGGRAVATING!! Anyhow, I read a consumer report on my truck (09 Tacoma TRD) and one person reviewing it said that they figured out how to do it w/o spending a dime and that it was easy.. Anyhow, if someone can help me out with this I'd be way grateful! If not , no sweat.. In the words of Steve Polycronopolis, I'll "DEAL WITH IT!".. lolz.. lata!
  2. Mar 16, 2009 at 5:49 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    1) Turn the Car 'ON', but do not start the engine (Leave your foot off the brake). Cycle your trip reset knob until it reads ODO. Turn the ignition back off. Wait a couple of seconds.
    2) Make sure seat belt is not fastened
    3) Turn the ignition back on, do not start the car (Leave you foot off the break) As soon as you see everything light up, press and hold the trip reset knob and do a long 12 second count.
    4) Keep your finger on the trip reset knob. Fasten your seat belt, as soon as you fasten your seat belt, you should see the ODO display go from XXXX miles to "b-on". At that time take your finger off the trip reset knob and press it again. It should cycle to "b-off". You should be all set and turn the ignition off and unfasten your seat belt.
    This worked on my 08, should work on your 09, worth a try!
  3. Mar 16, 2009 at 6:32 PM
    Okkine
    Okkine Well-Known Member
    Vancouver, BC
    2009 Magnetic Grey Access Cab - 2.7L I4 - 4x2
    Yep, it works on the '09's... Did this one before I even drove it off the lot.
  4. Mar 16, 2009 at 6:33 PM
    Okkine
    Vancouver, BC
    PS: Welcome to TW :thumbsup:
  5. Mar 16, 2009 at 6:38 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Or you can dismantle the steering colum and unhook the two wires ?
  6. Mar 16, 2009 at 7:56 PM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    Subscribed for later use. :)
  7. Mar 16, 2009 at 8:19 PM
    TL697
    TL697 Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    Thanks guys...
    I live in the mountains and am getting in and out opening and closing gates. The beeping was really annoying...
    Worked like a charm on my '09... The dealer couldn't even help me do it while I was there today...
  8. Mar 16, 2009 at 9:00 PM
    tamer
    tamer hamerworx.com
    SoCal
    2009 SR5, 4x4, V6, 6-Speed AC, MGM
    Does this trick do the passenger and driver?
  9. Mar 16, 2009 at 9:17 PM
    seaNOmercy
    Thanks oldtacomaguy, that'd been buggin me for awhile now, I'm so glad it worked! Thanks again!
  10. Mar 16, 2009 at 9:22 PM
    Okkine
    Vancouver, BC
    The write up in the mods section has instructions for driver and passenger, but the driver side instructions (which is what was posted here) disabled both for me.
  11. Mar 16, 2009 at 10:06 PM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    Yup, this one works for both. It's a must. I have it printed out and put in my manual, because you'll need to re-enter it if your ECU ever gets reset.
  12. Mar 17, 2009 at 8:40 AM
    oldtacomaguy
    Dave
    SE Conn.
    Your welcome, but all I did was cut and paste it from Piercedtiger's cheap/free mod page.
