How do I fix Rear end align issues?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gbtoy4x4, Aug 17, 2011.
  1. Aug 17, 2011 at 1:38 PM
    gbtoy4x4
    gbtoy4x4 [OP] Well-Known Member
    Greg
    Las Vegas
    2010 Silver TRD AC OR 4x4 6sp
    Factory Silver Sport Grill, Gray TRD Shift Knob, BFG 285/75/16 AT's, Debadged, AFE Cai, TRD Short Shifter, Redline Hood Struts, Leer Topper, Budbilt Front, Mid+Xcase Skids, ELocker Skid, Icon C/O, Built Right UCA's, Rear 2in AAL w/Bilstiens, AP U-Bolt flip, 1" 4Crawler Body Lift, Relentless Front Bumper w/Lights + Sliders, Rear Breather Mod, 5 ProComp 7089 Rims, AP SS Brake Lines, Famous Fab HC Rear Bumper W/Swing Out Tire Carrier, Synthetic Brake Fluid, Synthetic Power Steering Fluid, Front Superbumps, Hood Blackout,
    After installing Wheeler 2in AAL and Allpro shackle flip, I now have an issue with the rear end out of alignment.
    Went to align trk after installing Icon C/O and BuiltRight UCA's and couldn't get into good specs.
    Went to the toyota frame shop, said frame was straight, but rear end out of alignment, so it was throwing the front out of whack.
    Shop said it was like 26deg out,(26 seems alot) what was out not sure, he was sorta of vague, but maybe toe. That would also mean 1 tire would be toe out and other be in. Other than pulling up the toe out tire
    Any suggestions??
    LR
    Camber -1.3
    Toe .46
    RR
    Cam .7
    Toe -.21
  2. Aug 17, 2011 at 1:42 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    take it to an allignment shop and have them allign it?
  3. Aug 17, 2011 at 1:52 PM
    gbtoy4x4
    Greg
    Las Vegas
    Waiting on quote now
    I would think loosening u bolts to get rear to align would be standard procedure
    Someone posted on TW there is small amount of play in the rear
    But he sounded like it would be a big deal or something to that effect.
    Trk is at the shop now
  4. Aug 17, 2011 at 3:03 PM
    Tacoma Mike
    Southern Maine
    Your RR wheel is further back and your LR id further forward.
    Your LR is tilted in and right rear is tilted out.
    Have you tweaked the rear axle ???
    IT shows the signs of being hit the LR quarter towards the pass front quarter.
    You really need to double check your axle mounting which would put you close.
    Wish i knew your thrust line. As far as your camber you have a issue there.
    How was this truck wearing tires before you did all this work?
    If anything it's going to dog track with the right rear hanging out per say.
  5. Aug 17, 2011 at 3:39 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Did you install one of the leaf packs backwards?
  6. Aug 17, 2011 at 4:19 PM
    Tacoma Mike
    Southern Maine
    Yea i had that in mind too...
  7. Aug 18, 2011 at 11:13 AM
    gbtoy4x4
    Greg
    Las Vegas
    Didn't take leaf pack out
    And AAL was same length from center hole out
    Thrust angle .33deg
  8. Aug 18, 2011 at 11:16 AM
    neoflex
    neoflex Well-Known Member
    I think you said i was getting aligned now but I would bring it to the Toyota dealer to align it if you haven't. They charge the same price whether you do a front align or all 4 wheel alignment. I just had mine done this past weekend there for $68. I asked for a front end alignment but they had done all four for me since they don't charge extra for the rear.
  9. Aug 18, 2011 at 11:16 AM
    2kool4school
    2kool4school Well-Known Member
    Beau
    Honolulu, HI
    '12 JKU Sport
    Go to Firestone, they have lifetime 4 wheel alignment for like $120
  10. Aug 18, 2011 at 12:20 PM
    gbtoy4x4
    Greg
    Las Vegas
    Getting trk back in a minute
    Going to put stock ubolts and take out AAL then try and have it aligned
    I have access to an alignment machine
    Took it to toyota frame shop to make sure there is no frame damage and they are the 1 that said couldn't align since the rear end is out of whack
    On a 4 wheel align, they can't leave off the rear align mirrors and just align front, its a package deal, machine won't work
    And NO I don't want to be that guy /\
  11. Aug 18, 2011 at 12:27 PM
    2kool4school
    Beau
    Honolulu, HI
    '12 JKU Sport
    why remove the AAL just get the alignment with them on
  12. Aug 18, 2011 at 12:35 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
