How do I fix this?!
Discussion in '1st Gen. Tacomas (1995-2004)' started by GMack52, Jul 4, 2015.
  1. Jul 4, 2015 at 8:06 PM
    GMack52
    GMack52 [OP] Well-Known Member
    Garrett
    Clermont, FL
    2001 Tacoma SR5 TRD
    bed liner, that's it for now
    It just keeps getting worse. It's now spreading to the hood aswell! Is repainting the only option? Can I get the clear coat sanded and sprayed? what are my options?
    Thanks!
  2. Jul 4, 2015 at 8:08 PM
    300AACTaco
    300AACTaco Well-Known Member
    Alaska
    Black '15 DCSB TRD Off Road 4x4
    ARB Old Man Emu 90000s and 60091s OME 886s, Trim Packer, Icon Tubular Uniball UCAs, CMC, Invisible Sway Bar, Dakar Rear Leaf Packs, Timbren Rear Bumpstops, All Pro U-bolt flip up kit, Method Race Wheels NV 16X8 4.5BS, Cooper ST Maxx LT285/75/16, DEPO Black Tail Lights, Weathertech Floormats, Cascadia Vehicle Tents Mt. Shasta in Earth Tone Green, Custom Green Tree Fabrication Bed Rack, N-Fab Spare Tire Bed Mount
    Possibly try wet sanding, then compounding with a microfiber cutting pad on a dual action buffer, followed by a paint polish, but it looks like the clear coat is failing, and where there's no clear coat its really hard/almost impossible to fix.
  3. Jul 4, 2015 at 10:43 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Should be able to wet sand and respray clear. If done properly shouldn't be able to tell
  4. Jul 4, 2015 at 11:30 PM
    logcabinwc
    logcabinwc Well-Known Member
    Micah
    SF East Bay
    08 4d 4x4 White V6 TRD
    Old Man Emu 885s with Nitrocharged 90000, Bilstein 5100 in the back with AllPro 3 spring progressive AAL, 16 inch Baja Black 6-spoke alloy wheels, Flow Master exhaust, bed lights, Pioneer HD radio, Uniden CB Radio, K&N Air filter, BAMF Sliders w/kickout, Relentless Aluminum IFS Skid, 24 LED light bar, custom/homebuilt expedition style bed rack and basket combo, and Body Armor rear plate bumper.
    Just once you fix, wax your truck regularly.
  5. Jul 5, 2015 at 12:03 AM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
  6. Jul 5, 2015 at 12:47 AM
    300AACTaco
    Alaska
  7. Jul 5, 2015 at 12:55 AM
    TashcomerTexas
    Agreed. I just detailed my truck this past evening (not to take away from the topic)
    Kind of like a love-hate relationship, it's muddy one day but you got to maintain that paint!
    Looks like OP might have his hands full, the whole panel needs to be redone.
  8. Jul 5, 2015 at 1:26 AM
    300AACTaco
    Alaska
    Same here! I just washed it yesterday and I'm going mudding today lol, I need to find time to put a sealant on it to protect that paint. And yeah that thing needs some real TLC! That Ammo NYC video you shared is really helpful I've seen it before, only thing about that is when wet sanding you take a lot of clear coat off so you can't really ever get too aggressive with that area ever again. Then again it looks like you're only option besides having it repainted. Which costs a A LOT to have done by a really good professional.
  9. Jul 5, 2015 at 5:21 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    when shit like that gets started, its like a cancer that keeps coming back, soon its going to be like that across the entire truck and any of the clear coat that isn't a problem now, will separate and be a problem later.
    sure you can do spot detailing to help some spots but there are no short cuts or half measures that will work here, the clear coat needs to be sanded off the whole truck then at this point its silly not to do a repaint (its already sanded and prepped) then cover that with another clear coat. in the long run this is the only solution to not have to deal with this issue again, plus it upgrades the truck value to have a nice fresh new paint job.
  10. Jul 5, 2015 at 10:48 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    The same thing started to happen on my roof, even with religious waxing and clay barring. The only thing that prevents this is having a garage kept truck. As you can see from my sig (if you're on a desktop), I simply sealed up the problem before it got any worse, by using plastidip. $200 in supplies.
  11. Jul 5, 2015 at 9:06 PM
    NOLA ItsNotOva
    NOLA ItsNotOva Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    I got it much worse than you lol
  12. Jul 5, 2015 at 9:14 PM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    Youd be rusted out here...
  13. Jul 5, 2015 at 9:16 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    I'm suprised it hasn't gotten worse. Its spread since I got it, but it hasn't gotten worse. I was going to just plasti dip it for now but no that I dented the cab with a 2x12, I'll need to get it painted
  14. Jul 5, 2015 at 9:25 PM
    chadstacoma
    chadstacoma Well-Known Member
    chad
    mcclave,colorado
    2005 tacoma crew silver trd
    its to bad but iv done body work for yrs in my dad and granddads business and once its that far if you wetsand it the thing is is that the metallic is all sanded out and if you just reclear it then it will be a totally diff color and easy to see the only thing you can do to do it nice is just repaint the roof and hood. that way it all matches and looks good. my 89 red is doingthe same thing.the price autobody shops charge now is totally ridiculous by the way, the paint is cheap, the materials are cheap, the labor is easy, so I don't understand why they think a paint job is several thousand dollars?if there is no real body work then its a wetsand and get all the edges very good get it good and clean before you start spraying and you are good.just my opinion on that I guess. hope this helps and its cheaper than a complete as long as the rest of the truck looks ok.
  15. Jul 5, 2015 at 9:29 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    I work for a dealer that supplies parts to multiple body shops. Got a quote for $700 to do the hood and roof and the trim. Theres scratches and dents around the truck, but not as worried about it as I am with the hood and roof
  16. Jul 5, 2015 at 9:31 PM
    chadstacoma
    chad
    mcclave,colorado
    if that's total including everything that is a fair price, that's actually the best quote ive heard. so id do it if I had the cash for sure. it would be nice if there was a easy fix other than repainting but to my knowledge no one has came up with it yet. hope you get it lookin new again, they are worth it.
  17. Jul 5, 2015 at 9:35 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Yep. Thats total price. I'm actually debating on when to do that. Seems like every time I turn around, something breaks on my truck. I've had a brake issue for months and cannot for the life of me figure it out lol. Plus, the trans fluid is brown/somewhat black and I dont know the service history on the trans. So I wouldnt want to waste the money on getting it painted and then have the trans go out or something like that
  18. Jul 5, 2015 at 9:38 PM
    chadstacoma
    chad
    mcclave,colorado
    oh no kidding, im glad im not the only one that crap happens to, everytime I think I have the saved up cash for a grille guard for my 05 something on wifes car or house screws up and takes it all! that's happened many times over the last few yrs. it really ticks me off. but keep going it will get to the point of happening eventually.
  19. Jul 5, 2015 at 9:43 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    I got mine May of 2013. Since then I've replaced struts and shocks, air filter housing, MAF sensor, O2 sensor, inner and outer tie rods, upper and lower ball joints, tires, valve cover gaskets, carrier bearing, and some other stuff I don't remember lol. Plus, I had to pay over $1k for front end repairs after my accident. If it comes to something major going wrong, I'll just cut my losses and get another car/truck depending on what i can afford.
  20. Jul 5, 2015 at 9:44 PM
    chadstacoma
    chad
    mcclave,colorado
    yikes that is a lot but just think now its almost all new so it should go another 100,000? what yr is it?
