How do I get more weight capacity out of my Deaver J66s?
Discussion in 'Suspension' started by MicaTaco4.0, Feb 16, 2025.
  1. Feb 16, 2025 at 8:51 AM
    MicaTaco4.0
    MicaTaco4.0 [OP] New Member
    2nd gen Tacoma 4.0 4x4
    Grille Interior lights
    I recently purchased a set of very lightly used Deaver J66s for my 2013 Tacoma. Naturally after I bought them I read that they are only rated for 200 lbs constant weight. I am looking at buying a RTT and making a custom aluminum rear bumper for my truck which with the rest of my gear for off-road I’m guessing will be around 650-750 lbs. Am I able to take a leaf out of my stock pack(was replaced about 2 years ago so it’s not worn out) and add it to the J66 with an extended center bolt or is there a better option to get the 500 lbs extra weight taken care of. Hoping to not have to buy another pack. Any help would be appreciated thanks!
  2. Feb 16, 2025 at 9:40 AM
    Saskabush
    Saskabush Well-Known Member
    Adam
    Saskatchewan, Canada
    2013 TRD Sport
    Elka 2.5" DSC w/ Deaver Stage 1, Archive Hammer Hangers, SPC UCAs, Timbren bumps, TRD baja wheels, 265/75r16 Wildpeak AT4W, Greenlane Sliders, Warn slimline bumper, N-Fab spare tire box mount.
    Honestly I would just replace those. The J66's are not designed for extra weight. Even with an AAL they will likely struggle, plus they are already a tall pack so adding more height may not have the best results. And they don't even have overload leafs which are kinda needed with extra weight. This is really what the U402's are for. You're looking at stage 2 or even 3 for that weight. I'd look at Archive leafs as well for that setup.
    How did the J66's ride with an empty box? I was looking at those for my 2013 but went with U402 stage 1 instead, on Deavers recommendation. I love them but always was curious how soft the J66's actually were on a second gen. I find even the stage 1's still need a bit of weight in the box or they are a bit stiff.
    Steves104x4 likes this.
  3. Feb 16, 2025 at 11:31 AM
    MicaTaco4.0
    Thank you! I’ll look into new leaf packs I guess. Didn’t know if there was a better option or not. The J66s are amazing with around 100 lbs in the DCSB setup I have. Running 5160s with them and it rides like a dream, which is why I really don’t want to get rid of them haha
    Saskabush likes this.
  4. Feb 17, 2025 at 2:50 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    For what it's worth I have the Deaver U402 stage 2 with a camper shell, custom drawers/platform, and much more junk carried. Probably 400lbs or more daily. After they break in with that weight it will still ride great, but if all you carry is 100lbs normally go stage 1.
  5. Feb 17, 2025 at 2:55 PM
    JasonT87
    JasonT87 Well-Known Member
    Southern California
    '16 TRD Sport DCSB
    Total Chaos mid-travel front. JD Fab SUA rear.
    Different setup in the rear (camper) is going to require a different leaf setup. It’s just the name of the game. I have the JD fab SUA HD pack with my gfc and it works pretty well, but that might be a snowball effect for you.
  6. Feb 17, 2025 at 3:01 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I have Deaver Stage 3 with 650-700 daily weight, and I think its perfect for that. Or might be at the end of stage 2. Camper, HC bumper with swingout, full steel skids/sliders.
