How do I get rid of rubbing on new tires?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jacklu, Nov 3, 2018.
  1. Nov 3, 2018 at 9:50 PM
    Ch78
    Ch78 GBO!
    Tomball, TX
    25’ Landcruiser 1958
    Tuned By D3 Performance
    The obvious answer.
    Prairie Hawk[QUOTED] likes this.
  2. Nov 3, 2018 at 9:58 PM
    Ras61
    Ras61 Well-Known Member
    Arlington VA
    '12 4wd TRD Sport Dbl Cab
    Icons front, Bilstiens 5125 rear, 35/12.5/17 MT/Rs and some trimming
    Take the mud flaps off and put some clear bra to protect thr paint.
  3. Nov 4, 2018 at 12:51 AM
    jerryb1984
    jerryb1984 Well-Known Member
    Jerry
    2018 DCLB TRD OFF ROAD
    16x8 FUEL BEAST 265 75 16 FALKEN WILDPEAK AT3 Tyger step sides 20% tint front to match factory tint bilstein 5100s on third notch PRO grill
    Could just remove the front mud flaps unless you really like them. I have 16x8 0 offset with 265 75 16 and don’t rub at all, even off road. No mud flaps.
  4. Nov 4, 2018 at 1:10 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    265/75/16’s won’t rub with the stock wheels. Your problem lies there as already states. Wheel spacers will probably do the trick if you don’t want to ditch the mud flaps. I doubt it hitting the cab mounts or fender liners.
    Do you have the stock mudflaps?
    As others said sand them down or take a heat gun or something and try to reshape or cut away some of the material in the area where it’s rubbing. Have someone jump in the truck and cut the wheel and or slowly drive it to see where the rubbing occurs.
  5. Nov 4, 2018 at 1:33 AM
    MCDavis
    MCDavis Taco life is over. Full time 4wd for the win.
    RIC, VA
    2017 TRD Sport 4wd (SOLD) - Currently in a 2016 GX460
    Wheel spacers won’t help. He’s already on -6mm offset and wheel spacers will push the wheel and tire further out...making the rubbing while turning worse.
    Alignment first with 3* or more of caster.
    Then start trimming.
  6. Nov 4, 2018 at 1:44 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    You may be right, but usually the tires run in the inner part of the mud flap. I think the way the body and mudflap is designed the further you go out the greater the angle, as it’s not perfectly square to the tire. Thus moving the wheel out may stop the rubbing. If that is in fact the angle goes change. I’d have to look at it again, but this is common in most vehicles
  7. Nov 4, 2018 at 6:17 AM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    I believe he is stock other than the wheels and tires, no way is he getting 3* with stock UCAs.
  8. Nov 4, 2018 at 6:28 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    There is a reason Toyota says the max tire on a stock truck is 265/70/16, 265/70/17. You have entered the world of modifications. It probably is just the front mud flaps, if you have them. Do some searching on TW, you will find answers and opinions. Best of luck.
    Rockefelluh likes this.
  9. Nov 4, 2018 at 6:35 AM
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    FTFY
  10. Nov 4, 2018 at 7:25 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    265/75/16 does not rub with stock wheels, or wheels that match closely the stock offset.
    There seems to be some misunderstanding in this thread. Negative offset indicates more “poke” and pushes the wheels outwards, leading to rub when turning. The more negative, the more the wheels stick out. Spacers dramatically increase your negative offset. If you already have too much, they will make it worse.
    Positive offset narrows the track and may lead to rubbing on the UCA.
    There is a balance required to be in the sweet spot, but you can push the wheels outward some, as they do with the 16” OEM TRD Pro wheels, or the 17” OEM SEMA TRD 4-runner wheels, without causing rubbing on a non-lifted 3rd Gen Taco.
    tcjacado, Joe23 and jwctaco like this.
  11. Nov 4, 2018 at 8:20 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Spacer won't help. The further out you move the wheel the more likely you are too rub the fender .
    Heat gun is best choice
  12. Nov 4, 2018 at 4:22 PM
    MCDavis
    RIC, VA
    Really?
    I’ve got 3* on a 6” lift. It’s possible with a good alignment tech.
  13. Nov 4, 2018 at 5:01 PM
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    With stock UCAs?
  14. Nov 4, 2018 at 5:02 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Those wheels must be offset a lot, I have a 2017 with the same size and model tires on stock OR wheels with no issues, even when new before my lift. JaCado and some others had the best suggestion- some light trimming after you realign - not too invasive.
  15. Nov 4, 2018 at 6:16 PM
    #35
    MCDavis
    RIC, VA
    Correct
  16. Nov 8, 2018 at 6:26 PM
    #36
    Jacklu
    Jacklu [OP] Member
    2018 Tacoma
    Thank you everyone for all of the suggestions it seriously helped! I’m goin start first with removing the front and rear mudflaps being that I never really liked them and I know that it will at least help a little. I’ll make sure to post after with the results! If it still is rubbing at all I will probably take it in for an alignment
  17. Nov 8, 2018 at 6:30 PM
    #37
    SpeySquatch
    2016 TRD OR DCSB
    Oh get bigger tires...;)
    Prairie Hawk likes this.
  18. Nov 8, 2018 at 6:32 PM
    #38
    Jacklu
    Jacklu [OP] Member
    2018 Tacoma
  19. Nov 8, 2018 at 7:12 PM
    #39
    SpeySquatch
    2016 TRD OR DCSB
    I’m moving up from the same size.
    Going 255/75/17
  20. Nov 9, 2018 at 6:46 PM
    #40
    Jacklu
    Jacklu [OP] Member
    2018 Tacoma
    So I took off my mud flaps today and so far so good! It would rub every time I pulled into my work because of the snow right now and potholes but today it did not! I still think that I may run into some more rubbing issues when off roading because it still looks like it’ll rub when the suspension is compressed. Now time to find myself a nice suspension lift kit but am I really the only one experiencing rubbing on 265/75/16 on stock height!?
