How do I get this done?!?!!?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cland75, Sep 3, 2022.
  1. Sep 6, 2022 at 6:32 PM
    Cland75
    Cland75 [OP] Well-Known Member
    Kevin
    Piedmont NC
    99 Tacoma SR5 4x4
    Those that say the head moves off nice an easy sure are lucky
  2. Sep 6, 2022 at 8:04 PM
    MaxTorque
    MaxTorque Hope is not a strategy...
    Maryland
    cup holders
    For what it's worth, the correct name of the tool is "retaining ring" pliers. The tool is indespensible for putting on these retaining rings. And Wilde (USA) makes a great pair that has the serrations on the outside of the jaws and a dimple in each jaw that aids in capturing the ends if the retainer.
  3. Sep 6, 2022 at 8:52 PM
    MaxTorque
    Maryland
    cup holders
    Just an ok video. He should have filled the joint cavities with grease, and the remainder in the boots. And at around 35:25 he is installing a band clamp that he is unfamiliar with, and says you "just bend the clamp over." Wrong. There is a tool called a CV joint banding tool made just for this. It pulls the band tight, then you bend it over, secure it, and snap off the excess. A zip tie is a rookie move.
