How do I increase towing performance?
Discussion in 'Towing' started by TexasTacoTuesday, Aug 14, 2023.
  1. Aug 14, 2023 at 10:55 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Seems like an easy problem to solve.
  2. Aug 14, 2023 at 10:56 AM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    A burlap sack and a river?
  3. Aug 14, 2023 at 10:58 AM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    Nah man... new stuff is all plastic and computers. He needs something that he can wrench on himself that he doesn't need to get 15 year financing to afford...
  4. Aug 14, 2023 at 10:59 AM
    TexasTacoTuesday
    TexasTacoTuesday [OP] Well-Known Member
    Texas
    2017 DCSB SR5 V6
    4.5" lift, CMC, Maxtrac UCA's, Steel front and rear bumper, Ditch Lights, Rear pod lights, 2" rear lift, Pop lock tailgate lock, BAKflip MK4, 285s, Stinger Heigh 10.
    On a stock tacoma or a modded tacoma? I want to s/c mine anyways even if I'm not going to be towing the travel trailer.
  5. Aug 14, 2023 at 11:02 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Been my experience as well. RV service bays that aren't backlogged by 6 months are as rare as hens teeth. My trailer had a lot of issues that should have been under warranty, but I instead elected to fix it myself. At least now I know the wiring and plumbing intimately, as I have rewired and re-plumbed a good 70% of that trailer.
  6. Aug 14, 2023 at 11:05 AM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    heavy hauling in a gas truck is a complete waste of time
    TexasTacoTuesday[OP] likes this.
  7. Aug 14, 2023 at 11:11 AM
    SmoothTRD
    SmoothTRD Well-Known Member
    You can get a 3k, 3.5k lb trailer that should be plenty comfy. Whatever you do don't buy a Chevy! Complete garbage!
  8. Aug 14, 2023 at 11:18 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Around 4000-4500 lbs max is a realistic limit for a Tacoma. And that's on fairly level ground and under 5000' elevation. MOST 1/2 tons will be OK at around 6000 lbs, but some won't. Around 7000 is a more realistic limit for MOST 1/2-ton trucks. You still need to make wise choices.
  9. Aug 14, 2023 at 11:19 AM
    mic_sierra
    Elsewhere
    Total cost of ownership of a diesel is a complete waste of money, unless you are talking about a DD16 in a big rig :burnrubber: My 5.9 Cummins ran like a champ but dang, the repair bills sucked as well as filling up at the pump.
  10. Aug 14, 2023 at 11:24 AM
    TexasTacoTuesday
    Texas
    2017 DCSB SR5 V6
    ok cool yeah I see a couple of options that would work in my area that'll be about 4-4.5k fully loaded. I'm only traveling around the gulf coast so pretty much flat aside from a couple of bridges here and there.
  11. Aug 14, 2023 at 11:24 AM
    50Buck
    5K pounds isn't heavy hauling and a diesel is really expensive overkill. That's solid 1/2 ton work. If I were getting something that size I'd be shopping a 2018-2019 Tundra. Had a '19 and loved it, but when I decided I liked a RTT more than a trailer I downsized to the Taco.
  12. Aug 14, 2023 at 11:28 AM
    50Buck
    Honest question here, are you going to pull the heavy bumpers/mods off the Taco before you get this rig? I only ask because you're likely going to be way over payload with all that heavy stuff and a trailer on it.
  13. Aug 14, 2023 at 11:31 AM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    It's a TAA-coma not a TOW-coma.
    Proper tool for the proper job. Tacoma ain't it. Get a truck suited for towing.
  14. Aug 14, 2023 at 11:32 AM
    TexasTacoTuesday
    Texas
    2017 DCSB SR5 V6
    I'd rather not. The roads to the job sites I'm working on are pretty shit from what i've been told.
    50Buck[QUOTED] likes this.
  15. Aug 14, 2023 at 11:33 AM
    #35
    TexasTacoTuesday
    Texas
    2017 DCSB SR5 V6
    Yeah definitely not very practical or rational but I'd rather keep the truck and drop a shitload of cash on it to make it work than get a new truck.
    bhova and GTGallop[QUOTED] like this.
  16. Aug 14, 2023 at 11:36 AM
    #36
    50Buck
    Then honestly, I think you'll tear the tacoma up pretty badly from the added stress of trying to tow the trailer. Remember the pics of the chevy colorado with a bent frame from a little trailer on it? He was within capacities, but drove normal speed on rough roads. The bounce of the trailer fatigued the frame until failure. You have to tow slow on rough stuff.
  17. Aug 14, 2023 at 11:36 AM
    #37
    GTGallop
    Greg
    Anthem, Arizona
    Dash Cams and Hams!
    My '23 Taco struggles to carry me and a passenger with no other load up hills going from 2,000 ASL to 5,000 ASL over a 30 mile stretch. Add luggage or camping gear and it really bogs down. Have to keep RPM's up and drive it like a Manny-Tranny. Pulling a trailer (which admittedly I've never done in the taco) wouldn't be any easier.
    Or - put a different way....
    My Tacoma, unburdened, doesn't perform as well in the hills as my Ranger did with a trailer and load in the bed.
    At a minimum he needs a Turbo 4 or even better a Turbo 6. If not, then it's V8 territory.
  18. Aug 14, 2023 at 11:38 AM
    #38
    TexasTacoTuesday
    Texas
    2017 DCSB SR5 V6
    Oh damn, that's wild. But I won't be towing on rough roads. I'm just taking it to the closest RV park and driving from there through the rough roads without the trailer. Even on the highway I drive like a grandpa.
  19. Aug 14, 2023 at 11:39 AM
    #39
    50Buck
    I live at nearly 7k feet, and it's not that bad towing a light trailer. Just tow slow (like every manual out there tells you to) at 60-65 and don't expect to not be revving for hills or headwinds and it's fine.
  20. Aug 14, 2023 at 11:40 AM
    #40
    50Buck
    Ah, that's a huge difference. How often would you have to move the trailer? Are you living in it solo, or will you have a companion? Do you need a shower/bathroom in the trailer?
