How do i install front brake lines?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Anthony250, Dec 13, 2011.
  1. Dec 13, 2011 at 9:12 PM
    Anthony250
    Anthony250 [OP] Fabricator
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    What are the steps or what to do to install extended front brake lines for my 99 Tacoma Prerunner?
  2. Dec 13, 2011 at 9:17 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    Un bolt the old lines, bolt up the new ones, bleed brakes..
    Pretty straight forward. If you have never bled brakes before, you can find some guides online.
  3. Dec 13, 2011 at 9:18 PM
    TacoMX
    Jonathan
    Deltona, Florida
    btw, how do you like your 2.0 SAWs?
  4. Dec 13, 2011 at 9:19 PM
    Anthony250
    Anthony
    San Gabriel Ca
    Do i bleed system dry??
    They were aswesome shocks, held up great. Dont have them anymore.
  5. Dec 13, 2011 at 9:21 PM
    TacoMX
    Jonathan
    Deltona, Florida
    You can drain the system up front by pressing the brake pedal and opening the bleeder valves prior to breaking everything down. But you will drain everything when you remove your lines anyways.
    Also a good time to bleed all 4 brakes and get out any old fluid and to bleed out any air that may be hanging around....well you will probaby have to bleed all 4 anyways because you will probably run the reservoir dry anyways.
  6. Dec 13, 2011 at 9:22 PM
    Anthony250
    Anthony
    San Gabriel Ca
    Oh ok, i guess just unbolt them and try and control the mess, and pour in the new oil, how much oil does it take if i were to drain completely?
  7. Dec 13, 2011 at 9:23 PM
    TacoMX
    Jonathan
    Deltona, Florida
    Its not very much. Your average size brake fluid bottle should be enough....but buy a bigger one just in case.
  8. Dec 13, 2011 at 9:23 PM
    TacoMX
    Jonathan
    Deltona, Florida
    and what do you run up front now instead of the SAW's?
  9. Dec 13, 2011 at 9:24 PM
    Anthony250
    Anthony
    San Gabriel Ca
    I got a brand new regular size bottle ready. Will it gush out fast?
  10. Dec 13, 2011 at 9:25 PM
    Anthony250
    Anthony
    San Gabriel Ca
    Im now running 2.5 8" SAW. On stock arms, bumped and strapped, getting ready to install long travel kit thursday along with new brake lines.
  11. Dec 13, 2011 at 9:26 PM
    TacoMX
    Jonathan
    Deltona, Florida
    mmmm...shouldn't...but be prepared.
  12. Dec 13, 2011 at 9:29 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Uh, those little bottles (not sure what you meant by "regular size") are OK for topping off the system as your brakes wear, but I've never been able to bleed my brake system without using one or two of the "giant" bottles of brake fluid.
    Otherwise, still air in the system.
  13. Dec 13, 2011 at 9:31 PM
    Anthony250
    Anthony
    San Gabriel Ca
    12 oz. Ill try and plug up the line once removed.
  14. Dec 13, 2011 at 10:27 PM
    1998tacomaowner
    1998tacomaowner Well-Known Member
    chris
    clarkston WA
    98 toyota tacoma
    3in lift,33s
    it shouldent run out to fast just enough to piss you off
    and your prolly not going to drain the entire system but i think a 12 ounce can is going to cut it close
  15. Dec 13, 2011 at 10:50 PM
    Anthony250
    Anthony
    San Gabriel Ca
    I probably wont drain the whole system.
  16. Dec 14, 2011 at 1:33 AM
    mackattack07
    mackattack07 Well-Known Member
    william
    Jacksonville NC/Graceville FL
    99 Prerunner 3.4/2000 4Runner3.4/85 Pickup22R
    Helpfull hint find a rubber hose that will pop on the end of the bleeder screw run it in a jug then all the escaping fluid is controled learned this many years ago and it works
