how do I install the rear leaf spring u-Bolts for 2022 tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by stickbug1, Feb 27, 2025.
  1. Feb 27, 2025 at 11:31 AM
    stickbug1
    stickbug1 [OP] Member
    One of my rear leaf spring u-Bolts broke. while I was on a trip in another state. I had a friend welded it together as a temp fix until I got home. I ordered and got a new u bolt. How do I install the rear leaf spring u-Bolts for 2022 tacoma they shift around and don't know if they need to be straight or not how flush does the bottom knuckle thing have to sit.
    Anyone have a guide ?
    Note friend installed the welded bolt.
  2. Feb 27, 2025 at 11:34 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    If stock, the bump stop cradle keeps the u-bolt top from sliding up and down the leaf pack. Then you slide it through the axle housing flange that the leaf pack sits on. Then washer stack and nut.
  3. Feb 27, 2025 at 11:42 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    There's not much to it. If you're only replacing a bolt, then just remove the old one and pop the new one on and tighten down. IIRC it's around 75 ft/lbs for the factory style u-bolts, and 90-100 ft/lbs for a flip kit. This might help:
    https://youtu.be/ljheGhOSGbk?t=458
  4. Feb 27, 2025 at 11:44 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    There’s a locating pin on the leaf.
    If the pin is in the leaf. Its centered.
    Then, just put the u-bolt on and tighten it down.
  5. Feb 27, 2025 at 1:56 PM
    AZPhys13
    AZPhys13 Well-Known Member
    2021 TRD OR DCLB - MGM
    If you're question is about how much to tighten each ubolt, I just try to have the same number of threads beneath the nut on the front and back ubolt.
