How do I know if I have a limited slip differential?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1tacoplease, Feb 4, 2014.
  1. Feb 4, 2014 at 9:13 PM
    1tacoplease
    1tacoplease [OP] I like my truck!
    Temecula
    2008 BSP 4x4 6 speed
    265/70/17 BFG RT's, FJ 17" rims with 1.25" spidertraxx Debadged, HID's, URD short shifter, Bilstein 5100's in the front, TSB and 1" block rear, URD TCAI with maf calibrator, JBL long tubes, DT Y pipe, Gibson exhaust, Walbro 255 fuel pump, Pioneer stereo, Bak flip G2 tonneau, TRD skid plate, MB Quarts all around with dynomat, Viper Alarm with motion sensor
    I have a 2008 SR5 4x4 and every time I make sharp turns my tires screech. Is this an indication of an LSD or is this normal?
  2. Feb 4, 2014 at 9:14 PM
    medic2230
    Murph
    Bama! Roll Tide
    That may be an indication you're driving too fast around the corner. :D
  3. Feb 4, 2014 at 9:15 PM
    scocar
    scocar hypotenoper
    ROR!
  4. Feb 4, 2014 at 9:17 PM
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    screeching when turning would be the indication of a locker being locked. not an lsd. could be a totally different problem causing the screeching. look on your rear diff and see if there is a sticker that says "lsd oil only" or something like that to tell if you have a lsd.
  5. Feb 4, 2014 at 9:19 PM
    woof359
    woof359 Well-Known Member
    any toyota dealer can run your vin and pull up your equipment list
  6. Feb 4, 2014 at 9:22 PM
    rev25sharp
    rev25sharp Well-Known Member
    Al
    jacksonville fl
    Silver 17dcsb trd sport
  7. Feb 4, 2014 at 9:35 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    If your differential has this sticker, you have a mechanical limited slip.
  8. Feb 4, 2014 at 10:36 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Tire screech could just be an alignment issue too.
  9. Feb 4, 2014 at 11:06 PM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    lift both your rear tires off of the ground
    spin one
    if the other spins in the opposite direction: open
    if the other spins in the same direction: limited
    this applies to a mechanical LSD
    i'm not up to snuff on the Atrac, or whatever the heck, stuff
