How do I know if I have a TSB leaf pack??
Discussion in 'Suspension' started by Dakota 08, May 9, 2011.
  1. May 9, 2011 at 1:47 PM
    Dakota 08
    Dakota 08 [OP] Well-Known Member
    Portland
    08 Dbl Cab
    I have an '08 4x4 Dbl cab OR short bed. Is a TSB leaf pack an aftermarket addition? Did mine come with it stock?
  2. May 9, 2011 at 1:49 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yours did not come with it. Unless you bought the truck used and the old owner got the TSB done. If it has 3 leafs the work hasnt been done. I believe after the TSB, it has 4 leafs.
  3. May 9, 2011 at 1:50 PM
    paulm09tacoma
    paulm09tacoma Well-Known Member
    paul
    connecticut
    09 access cab trd
    correct. 4 is the number to have
  4. May 9, 2011 at 1:51 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    3 + 1 overload to be specific.
  5. May 9, 2011 at 2:00 PM
    Dakota 08
    Portland
    08 Dbl Cab
    Got it, thanks for the responses.
    New question: With that being known, I want to lift the rear to match the height of my front which will be the 1.75" setting on the billys. I have a topper over my bed and a rack on top of that. What would best suit my needs: 1.5 AAL, 2.0 AAL, other thoughts??
  6. May 9, 2011 at 2:00 PM
    KPT
    09 Prerunner
    1.5" with a topper should get you pretty level with the 1.75 up front.
  7. May 9, 2011 at 2:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Measure the senter of the axels, to the bottom of the fender, and see what the difference is. Therein lies your answer on how much lift you'll need.
  8. May 9, 2011 at 2:07 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    X2. I think a 2" AAL will be to high in the back. I'm lifted 3" up front and 2" in the back and I sit pretty darn level.
  9. May 9, 2011 at 2:16 PM
    Dakota 08
    Portland
    08 Dbl Cab
    Awesome, thx for the help everyone. Now, if only I could buy a set of 4 5100s anywhere, we could get this party started.
