how do i know if i have passive anti-theft or not?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacod, Nov 19, 2010.
  1. Nov 19, 2010 at 2:20 PM
    tacod
    tacod [OP] Well-Known Member
    Dan
    Kemblesville, PA
    '04 Xtra V6 TRD 4x4
    i have an '04 SR5,TRD that has keyless entry...but no alarm that i know of. how would i determine if i have a passive anti-theft device?
    my insurance is asking...they say that "this type of system activates automatically when you turn the ignition key to the off position and disables the vehicle by making inoperative the fuel, ignition or starting system."
    thanks in advance!!
  2. Nov 19, 2010 at 2:34 PM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    I believe that if you provide the VIN to the insurance company, they can determine if the truck was originally sold with that option. If an after market passive system was installed, it will not show up during the VIN research.
  3. Nov 19, 2010 at 7:29 PM
    tacod
    Dan
    Kemblesville, PA
    '04 Xtra V6 TRD 4x4
    they have the vin, but have asked me this question. i don't know the answer...maybe i'll try toyota or the dealer...
  4. Nov 20, 2010 at 6:38 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    By keyless entry do you mean the little remote that locks and unlocks the vehicle?
    Also if the ignition switch is in the off position isn't the fuel pump disabled, making the whole ball of was disabled?
    One of my other vehicle's had a remote start that if left running and some one got in and put there foot on the brake, with out the key in the ignition, it shut down the vehicle until the ignition key was inserted, into the ignition.
    I don't get it!
  5. Nov 20, 2010 at 10:51 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    There would be a chip in the key to disable the igniton. If it starts with an all metal key, it does not have passive security.
  6. Nov 20, 2010 at 11:09 AM
    Zork
    Zork Well-Known Member
    CA / KY
    04 PreRunner V6 D-Cab
    Alpine CDA-9885
  7. Nov 21, 2010 at 5:25 PM
    tacod
    Dan
    Kemblesville, PA
    '04 Xtra V6 TRD 4x4
    they are looking for some kind of "immobilizer" more powerful than the key...
  8. Nov 21, 2010 at 5:25 PM
    tacod
    Dan
    Kemblesville, PA
    '04 Xtra V6 TRD 4x4
    got it...regular old keys work in mine. thx.
  9. Nov 21, 2010 at 5:26 PM
    tacod
    Dan
    Kemblesville, PA
    '04 Xtra V6 TRD 4x4
  10. Nov 12, 2012 at 4:41 PM
    campotr
    campotr Active Member
    ca.
    08 PreRunner 6cyl.6speed
    I have a 2008 toyota tacoma, on the window it says: this vehicle is equiped with vehicle thief deterrent. Where is this thing at and how do I know I have it?
