How do I know if I have synthetic oil?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trdracing5, Aug 28, 2010.
  1. Aug 28, 2010 at 5:52 AM
    trdracing5
    trdracing5 [OP] Well-Known Member
    Elizabeth City, NC
    1995 Tacoma 4X4
    ARE Impulse Shell, BFG AT KO's
    I am trying to find out if there is a way to determine if I have synthetic oil in my truck or regular old dino oil. I need to change the oil and will continue to use synthetic if that is what is in the vehicle already (I believe that once you go with synthetic you shouldn't switch back to regular oil).
  2. Aug 28, 2010 at 6:08 AM
    shawnd2
    shawnd2 Well-Known Member
    Shawn
    Toronto, Ontario, Canada
    08 Tacoma Access Cab 4x4 TRD Offroad
    The whole once you change you can't go back is a myth. Put in what you want (dyno or synthetic) and just make sure to change it regularly.
    Shawn
  3. Aug 28, 2010 at 6:32 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    x2
    but synthetic gives you thousands of miles of latitude for whatever your 'regular' oil change is, if you're anything like most guys on TW! :p
  4. Aug 28, 2010 at 7:57 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It doesn't matter.
  5. Aug 28, 2010 at 8:08 AM
    GSRON
    GSRON Well-Known Member
    Ron
    Northern CA
    06 TRD Prerunner
    There are Federal rules and regulations stating that you MUST be able to mix diff brands of oils w/o damage to your engine.....
    Yes there are diff additive packages in diff oils and yes I'd change it out at first chance if I mixed oil brands but the short answer is mixing = NO DAMAGE....
    As far as warrenty? If a mfg requires a "certain" oil to keep you warr. They must provide that oil to you at no charge for as long as you are under warr. This is why you see "recomendations" but no "requirements"...
  6. Aug 28, 2010 at 8:26 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    What they said :taco:
  7. Aug 28, 2010 at 11:23 AM
    Tojo
    Tojo Well-Known Member
    Colorado/Arizona
    10 TRD Off Road 4x4
    Mobil 1 0-20W, Tacoma bed mat, tailgate anti-theft, oil filter drain hose, back seat headrest removal, a/c back seat platform, rear spring tsb, Tek.Prodigy P2 electric brake cntrl, Toyota Bed Extender
    if it was me, i'd just drain it and go with synthetic.
  8. Aug 28, 2010 at 11:56 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    x2^^^^^^^^^^^^^^^
  9. Aug 28, 2010 at 12:06 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    My last Toyota had 350,000 miles and was still running strong when I sold it useing nothing but dino every 3,000 miles.
  10. Aug 28, 2010 at 1:55 PM
    808TRDTaco10
    808TRDTaco10 Black Sand Mirror
    Justin
    Big Island, Hawaii
    10 Access Cab TRD OR 5AT 4x4; 08 Regular Cab 5MT 4x4
    TRD Off Road 265/75/16 Goodyear Wrangler Duratrac Load Range C | Toytec Ultimate Lift with Emu Dakar Leaf Packs | 3* Axle Shims, CB Drop, Sway Bar Relocates | AVS Vent Visors, AVS Bugshield | Scangauge II | Wet Okole Seat Covers | Weather Tech Floor Liners | Pop n Lock | OEM Bed Mat | Truxedo Lo Pro QT Tonneau Cover | TRD Cat Back Exhaust | Aftermarket Alarm System | Pro Coat "Electronic Rustproofing"
    Asked the dealer which kind of oil they put into at the factory and the guy said that they put in semi synthetic oil and he recommended either the semi-synthetic or full synthetic for future oil changes.
  11. Aug 28, 2010 at 2:36 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    I'd taste it first and see. Nutty flavor is synth for sure.
  12. Aug 28, 2010 at 2:56 PM
    bagster
    bagster Well-Known Member
    And dino oil tastes like real old chicken.
  13. Aug 28, 2010 at 5:21 PM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    That's a good point: petroleum oil provides excellent protection, shouldn't think otherwise.
    Going synthetic only makes sense if you extend change intervals. If you're staying with 3k, then use petroleum and save the money.
  14. Aug 28, 2010 at 9:33 PM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    I use Dino...always have, always will. Like fresh stuff running through my engine. Change every three k. However, I did use synthetic in my differentials and transfer case.
