How do I know if I need a tune-up?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zer0, May 4, 2014.
  1. May 4, 2014 at 2:01 PM
    Zer0
    Zer0 [OP] Well-Known Member
    SGV, California
    99 PreRunner
    Hello all. I have a 99 Tacoma prerunner 2.7L auto with 217k miles. How do I know if I need a tune-up? The car runs fine with no issues. I'm just curious because I think I am due for a tune up because of mileage. If the car is running fine should I still do a tune-up or should I do it because of the high miles? Last tune up was done at around 180k.
    What is normally done in tune up? If I do tune up I plan on cleaning the intake manifold and throttle body, replace PCV valve, spark plugs and cap/rotor, oil change, and fuel filter. Does this cover a basic tune up or is there more I should do? Thanks.
  2. May 4, 2014 at 6:20 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Include a new air filter as well, and lube the u-joints. Your truck does not have a distributor, so no cap/rotor.
    I'd also check the valve adjustments. Easy to check, but hard to adjust.
  3. May 4, 2014 at 8:15 PM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Radiator flush and fill would be on my list also.
