How do I know if my 01 is Keyless Entry?
Discussion in 'Technical Chat' started by elmelanson, May 24, 2009.
  1. May 24, 2009 at 9:58 AM
    elmelanson
    elmelanson [OP] New Member
    Bedford, NS
    01 PreRunner 3.4L Xtra TRD
    Just purchased an 01 SR5 that has power locks. Dealer said it was remote entry but didn't have the fob. How do I know if this unit has factory remote entry?
    Thanks
  2. May 24, 2009 at 5:46 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    It may have remote / keyless entry, but it can't be 'factory'.
    Remote keyless entry was first offered as a factory option with the Power Package in the 2003 model year.
    However, it's possible the truck was fitted with a *dealer-installed accessory* or aftermarket alarm system with remote keyless capabilities.
  3. May 24, 2009 at 5:49 PM
    elmelanson
    Bedford, NS
    Thanks for the info EnolaGaia. I was likely fed a line by the dealer.
  4. May 24, 2009 at 5:57 PM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    Well ... Maybe yes, maybe no ...
    The dealer might simply have mistakenly referred to it as 'factory' ...
    As I said earlier - it's possible your truck was fitted with a dealer-installed Toyota alarm system (which *could* have keyless entry capabilities).
    If the 2001-era TVIP alarm system was installed by an authorized dealer, there should be a small control box / unit attached to the wall behind your driver-side kick panel. That was the standard / prescribed location for mounting it. The install instructions say it was installed using two-sided tape and a large tie.
