How do I make my truck capable of towing 6500 lbs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by silverej, May 29, 2010.
  1. May 29, 2010 at 6:13 AM
    silverej
    silverej [OP] Member
    Texas
    2008 PreRunner
    Receiver hitch
    I have a 2008 Double Cab PreRunner with the 4.0L and automatic transmission. It is rated to haul 3500 lbs. What do I have to do to have it capable of hauling the full 6500 lbs that a Tacoma with the Towing Package is capable of hauling?
  2. May 29, 2010 at 6:51 AM
    grammy
    grammy Well-Known Member
    Newfoundland, Canada
    4x4 v6 X-Cab
    Add the factory towing package. Its been done, you'll find instructions if you search.
  3. May 29, 2010 at 9:54 AM
    JKD
    JKD Well-Known Member
    Go with non-factory parts for the trans and engine oil coolers. The factory parts are ungodly expensive for what they are.
    The alternator and battery upgrades are kind of puzzling...I know that one of the reasons they upgrade an alternator is to provide run/charge current to a trailer that has its own electrical system with a battery. If you're not doing that I doubt that there is any reason to upgrade those parts.
  4. May 29, 2010 at 10:57 AM
    silverej
    Texas
    2008 PreRunner
    Receiver hitch
    What about the suspension? Does that need to be beefed up?
  5. May 29, 2010 at 10:58 AM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Buy a Tundra
  6. May 29, 2010 at 10:59 AM
    tacomaprerunner
    tacomaprerunner Dang liberals.
    1995 Ford F350 7.3L PowerStroke Diesel
    What do you plan on towing that is 6500 pounds?
  7. May 29, 2010 at 11:02 AM
    joes06tacoma
    Joe
    Central Coast, CA
    Mine has factory tow package and still has the crappy two leaf springs that everyone talks about on here. If you can get the tsb springs, I am sure that would be best. I have yet to tow anything, but I have had 1000 lbs in the bed and it was still not on the bumpstops, very close though.
  8. May 29, 2010 at 1:39 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Trailer brakes? Extra load from lighting? Just a couple I could think of.
  9. May 29, 2010 at 2:03 PM
    JKD
    Stock alternator is 100 amps, trailer towing alternator is 130. It's a decent upgrade, but trailer brakes shouldn't draw more than 10 amps and the extra lighting won't draw more than about 3 or 4. Stock base alternator isn't anywhere close to maximum output even running with all the accessories on--should be fine for towing.
    ETA: More than one pair of trailer brakes could get you up to 12-14 amps there. Still not enough to concern me.
  10. May 29, 2010 at 4:18 PM
    Barnone
    Barnone Guest
    I wouldn't worry about the battery or alternator, you could always add them if needed.
    The transmission cooler would be my first install if I was towing where there were hills or mountains. Like JKD said I would go with after market for the trans cooler.
    How about first installing a transmission oil temp gauge if your truck doesn't have one?
    That way you see if you actually need a transmission cooler by seeing what the temp runs without and with the trailer.
    Maybe get the ScanGuage.
  11. May 29, 2010 at 4:21 PM
    The End
    The End Support our troops!
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    2.5 King RR in front, LR ucs' s, 2.0 King RR rear, B.A.M.F shock mounts, ATO shackle flip, 4X sliders, ARB front bumper with XRC8, CBI hc rear, weathertechs, Leer cap, Thule rack, ubolt flip, etc.
    I would upgrade the brakes as well.
  12. May 29, 2010 at 4:30 PM
    kanelakos
    kanelakos Well-Known Member
    Binghamton, NY
    16 DC LB Sport
    I dont think tow package alone will do it. 4WD is needed WITH tow package to get to 6500..... I think....:D
  13. May 29, 2010 at 4:40 PM
    Barnone
    Barnone Guest
    I'm sure that you have to have trailer brakes to be legal so the stock brakes should do fine.
  14. May 29, 2010 at 4:53 PM
    The End
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    I see trailers everyday hauling way more weight than that without trailer brakes. It's never a bad idea.
  15. May 29, 2010 at 5:15 PM
    dexterdog
    Oly WA
    2012 F150
    You would be surprised at the amperage draw with accessories(max AC, lights, stereo maxed, etc.) working with the vehicle at idle. In some vehicles the battery is actually at a state of discharge with the engine idling due to the alternator not putting out peak amperage at lower rpms.
    The additions related to the towing package would be a reasonable assumption for a larger alternator.
  16. May 29, 2010 at 8:03 PM
    RognChris
    RognChris Member
    Roger
    29th st Newport Beach, Ca
    Silver 2009 Tacoma sport access cab
    You're forgetting the most important upgrade,
    17" wheels and a 371 ratio L/S diff.
    If you really want to tow even 5500 LBS, trade it in on a new one.
  17. May 30, 2010 at 7:22 AM
    Ultima GTR Guy
    Ultima GTR Guy Active Member
    Carlsbad, CA
    09 Double Cab Short Bed TRD Sport
    I regularly tow my race car on an aluminum Featherlite car trailer. That combo weighs about 3700#s dry. I have used the same trailer to tow my Z06 (about 4500#s). Even tho I have the factory tow package rating the truck to some 6500# capacity, I would not want to tow that much weight up and down the mountains in CA very frequently. I would frankly suggest you get a bigger truck to Regularly tow that much weight.
  18. May 30, 2010 at 7:28 AM
    07trd4x4
    07trd4x4 Well-Known Member
    Greg
    Truckee/Sacramento CA
    LX570
    Maybe a stupid question, but I thought 4wd is heavier which possible brings the amount you can tow lower!?!?!
  19. May 30, 2010 at 7:32 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    It generally does, but the 4x4 and Prerunners are ratted the same. Technically, the 4x4 cant haul as much, being as it weighs a little more than the Prerunner.
  20. May 30, 2010 at 7:40 AM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    yes technically our truck is better at towing. hah ha ha.
