How do I properly use a front locker?
Discussion in 'Off-Roading & Trails' started by EatSleepTacos, Aug 3, 2020.
  1. Aug 4, 2020 at 1:04 PM
    #41
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    I'll be sure to do that. lol
    Axles get buried and rigs get high centered all the time. Snow conditions are what make that happen. This was fresh dry powder. It doesn't compact enough to cause issues. 3 days later after it gets a few thaw cycles that's a different story. But, you already knew that since you do so much snow wheeling. lol
    Hobbs likes this.
  2. Aug 4, 2020 at 2:43 PM
    #42
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    try not to go out in 3-4 foot snow
    not even walking
    for years i was a responder on call out...........had to go
    seldom got powder
    had to pick/choose routes
    pulled more 4wheelers out o ditches ............up hills than anything
    mostly tyres were near worn out
    otherwise pilot error
  3. Aug 4, 2020 at 3:18 PM
    #43
    6 gearT444E
    Deep South
    Herculiner Hootus
    That be it. I’ve ran it multiple times in the past without issue but got stuck on a bad line that time around.
  4. Aug 4, 2020 at 3:23 PM
    #44
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah, it seems to need a specific line or it's just a bunch of frustration otherwise. I've only tried it the one time in this pic but couldn't make it through without pulling winch, so I just backed off and went about my day.
  5. Aug 4, 2020 at 6:15 PM
    #45
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I thought of another question for those with arb lockers. Can they be engaged/disengaged instantaneously? In the scenario I’m imagining, I’ll engage it, do a small part of the obstacle, disengage it, move a little more, then re-engage it.
    edit: only turning it on/off while stopped
    Or are they like the factory e lockers that require a little finesse and wiggling about to get it to engage.
  6. Aug 4, 2020 at 6:19 PM
    #46
    ROAD DOG
    FEW
    not to be recommended
    it is possible to get an IFFY partial disengagement / engagement
    resulting in chipped/broken teeth ( grenade !)
    no doubt it has been tried...................on exception with success
    good luck
  7. Aug 4, 2020 at 6:42 PM
    #47
    theesotericone
    Bishop CA
    Yes they can. Unlike e-locers ARB locks and unlocks instantly as long as there is no torque being applied to the unit.
    Everyone I wheel with does that. You'll crawl up something locked but need to adjust. You turn the locker off, back up a bit while turning the wheel , turn the locker back on then proceed ahead. The main benefit of a being able to unlock is it frees up the steering. When your locked it can be very hard to turn the wheel.
    Might want to quit while your behind.
    "When you need the extra traction, simply turn on your compressor, approach the difficult terrain, take your foot off of the accelerator and press the Air Locker switch – even if you are still moving"
    Page 4 under "Operating instructions".
    https://www.arb.com.au/site/wp-content/uploads/2019/11/13916-AirLocker_Op_Serv_Manual_11.pdf
  8. Aug 4, 2020 at 6:45 PM
    #48
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    This is exactly what I was imagining, thank you.
  9. Aug 4, 2020 at 7:37 PM
    #49
    ROAD DOG
    FEW
    not behind ..........??????
    ' no torque ' sometimes truck is in a bind
    next post actually mentioned back up .............. release torque /tension
    1st person anecdotal is gospel as long as it works
    liike NO 1 has ever damaged a locker ever
  10. Aug 4, 2020 at 11:23 PM
    #50
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    I suppose another good question is the journey the goal or is the destination the goal.
    Quite a few folks go and find the roughest terrain they can and conquer it. It might just be a mud bog or pile of rocks they can approach in 2WD. And once through motor away.
    For others, and I’m mostly in this group, use the vehicle capability to overcome obstacles on the easiest route to a destination.
    Now just because a route is the easiest doesn’t mean it’s easy.
  11. Aug 5, 2020 at 3:54 AM
    #51
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I go and seek out rough terrain for the sole purpose of conquering it. I like to push the truck to its limits and see what it’s capable of and I also enjoy the problem solving aspect of getting through some gnarly stuff.
  12. Aug 5, 2020 at 6:54 AM
    #52
    Greg.Brakes.Tacos
    Greg.Brakes.Tacos Don't Feed the Animals
    Greg
    Between Richmond and Virginia Beach
    2017 Taco DCSB TRD off road
    wanna be mods
    FTFY
    whatstcp likes this.
  13. Aug 5, 2020 at 7:02 AM
    #53
    JEEPNIK
    Cool. Then you know sometimes things are going to break. The challenge is figuring out what is most likely to break and having the tools and parts to fix it
  14. Aug 5, 2020 at 7:04 AM
    #54
    theesotericone
    Bishop CA
    I don't know what your talking about. lol
  15. Aug 5, 2020 at 7:07 AM
    #55
    Greg.Brakes.Tacos
    Greg
    wanna be mods
    Besides a little duct tape lovin'...nothing to see here, Carry on, keep moving folks, Carry on, nothing to see here...
  16. Aug 5, 2020 at 8:05 AM
    #56
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Absolutely, just part of the game.
    I’m pretty prepared with spare parts and fluids and tools.
    Greg.Brakes.Tacos likes this.
