How do I remove alarm system on 97 Tacoma??
Discussion in '1st Gen. Tacomas (1995-2004)' started by Alwaysdaily, Aug 7, 2019.
  1. Aug 7, 2019 at 7:03 PM
    Alwaysdaily
    Alwaysdaily [OP] Active Member
    Ty
    97 Tacoma 2.7l DLX
    I’m on vacation and lost my keys and key fob in the ocean ........
    I have a back up key
    But not a back up key fob and when I open the doors with out a key fob my alarm goes off, and I have to unplug the battery to make it stop. how do I remove the system completely.
  2. Aug 7, 2019 at 7:07 PM
    Alwaysdaily
    Ty
    97 Tacoma 2.7l DLX
  3. Aug 7, 2019 at 7:09 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    It won't be easy. It would not be much of an alarm system if it was easy to defeat.
    GQ7227 likes this.
  4. Aug 7, 2019 at 7:14 PM
    Alwaysdaily
    Ty
    97 Tacoma 2.7l DLX
    I just need to disable it so I can drive my truck home from vacation @tomwil
  5. Aug 7, 2019 at 7:14 PM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Can’t you get another key fob from a nearby dealer?
  6. Aug 7, 2019 at 7:18 PM
    Alwaysdaily
    Ty
    97 Tacoma 2.7l DLX
    I can’t drive anywhere I’m literally stuck until I figure out how to disable the alarm. @black coffee
    GQ7227 likes this.
  7. Aug 7, 2019 at 7:19 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    can you cut a wire and reattach it later?
    is it a custom alarm?
  8. Aug 7, 2019 at 7:22 PM
    Alwaysdaily
    Ty
    97 Tacoma 2.7l DLX
    Please do not reply unless you know how to disable the alarm. And have a real solution.
  9. Aug 7, 2019 at 7:23 PM
    Alwaysdaily
    Ty
    97 Tacoma 2.7l DLX
    Stock alarm
    GQ7227 likes this.
  10. Aug 7, 2019 at 7:40 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Is this the factory RS3000 alarm system? I dunno if that system interfaces with the ignition, but I would start with just unplugging the brain from the harness. It’s in the driver’s side kick panel if I remember correctly.
    What’s keeping you from driving away again?
  11. Aug 7, 2019 at 7:41 PM
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    Have you tried to insert the key in the ignition and start the Tacoma? It might shut off the alarm.
    Had a similar situation where the key fob battery went dead, and had to use the key to unlock the door which set off the alarm. However, once I inserted the key in the ignition and started the vehicle, the alarm stopped.
    Wyoming09 likes this.
  12. Aug 7, 2019 at 7:53 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    My alarm is aftermarket
    I’m able to put in valet mode with key in ignition and input code on hidden push button switch.
    Is there a toggle switch somewhere?
  13. Aug 7, 2019 at 8:10 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    If this system cuts your ignition wires, simply cut the harness where it interfaces with the alarm system and wire tie the factory ignition wires together. When you get home, solder the connection to make it permanent.
  14. Aug 7, 2019 at 8:28 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Search “how to disable a car alarm” on YouTube - there’s enough videos on it to figure out what to do - I removed one from my truck. Most have a relay you can jumper on the ignition control wire under the dash. Just start at the ignition and follow the wires to find the relay.
  15. Aug 8, 2019 at 4:32 AM
    Alwaysdaily
    Ty
    97 Tacoma 2.7l DLX
    Alright thanks for the help I’ll let you know how it goes.
    GQ7227 likes this.
  16. Aug 8, 2019 at 6:25 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Can you cut the wire to the horns or to whatever generates the sound?
  17. Aug 8, 2019 at 6:32 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You can just pull the horn relay in the engine bay fuse box if it’s running and the horn going off is the only issue.
    cruiserguy likes this.
  18. Aug 8, 2019 at 6:54 AM
    Alwaysdaily
    Ty
    97 Tacoma 2.7l DLX
    It’s a RS3000 alarm system.
    I took the horn fuze out to stop the noise. But the lights are still flashing. And the ignition system is still disabled, it won’t let me turn the key to start.
    GQ7227 likes this.
  19. Aug 8, 2019 at 6:58 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Arnold lifted the rear of the car to stop the alarm in Twins. You should try that.
    cruiserguy and Dalandser like this.
  20. Aug 8, 2019 at 7:03 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    @Alwaysdaily have you been able to search around the area where you lost your original key and fob
    i understand the frustration
