how do i remove back interior panels?
Discussion in 'Audio & Video' started by jasonm, Mar 2, 2010.
  1. Mar 2, 2010 at 7:41 PM
    jasonm
    jasonm [OP] Member
    Virginia
    07 TRD Sport
    Truxx Leveling Kit, 285 70 R17 MTR's, K&N Intake, Throttle Body Spacer, Pioneer Touchscreen Media Player.
    i was wondering if anyone out there knows how to remove the plastic panel (the part under the rear window) and the seat backs out of the back of an 07 extended cab taco?
  2. Mar 2, 2010 at 7:54 PM
    nxtruck
    nxtruck Member
    Basically, just pull. I didnt fully remove mine, but I pulled it loose enough that I could run some wire and a small project box behind the rear "seat". I started at the bottom near the door sill, then slowly pulled all the clips up the edge to the top corner, then pulled the clips towards the center of the seats. I didnt encounter any bolts that I recall, though I know there are some around the headrest.
    As long as you pull the clips directly forward I dont think you will have a problem removing it.
    edit: Mines a '10 access cab
  3. Mar 3, 2010 at 9:37 AM
    Outlaw
    Outlaw Well-Known Member
    Iowa City, Iowa
    2006 GX470
    Water Pump, Timing Belt, Sparkplugs, Plastidip Grill emblem
    You might check in the audio section or on ********* website for video or detailed instructions.
  4. Nov 26, 2010 at 6:26 AM
    rickand
    rickand Member
    Concord, MA
    01 Xtra cab 4WD auto 4 cyl
    the plastic panel simply pulls off (pry up at one end). then unbolt the padded backrest, then the lower panel pulls off.
  5. Nov 26, 2010 at 11:38 AM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    if those panels are the same as in a reg cab they do just come right off with a little tug.they got those plastic push things holdin em on.
