How do i remove front end?
Discussion in 'Technical Chat' started by jerris, Dec 7, 2009.
  1. Dec 7, 2009 at 11:55 AM
    jerris
    jerris [OP] Well-Known Member
    jerris
    utah
    07 double cab, 6 inch fabtech 35 duratrac
    6 inch lift, 35 inch duratrac's
    can any help guide me to getting the front end out of my truck i am going to re gear it? im not sure how to remove te axles from the diff so i can pull it out.
  2. Dec 7, 2009 at 12:19 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    I'd say the easiest way would be:
    -Break loose the lug nuts
    -Jack up front of truck, put stands under frame rails to support it.
    -remove front tires
    -loosen the bolts that hold the lower UCA ball joint to the knuckle
    -pop out the inner shaft of the CVs from the differential by lightly prying between the shaft and differential(I think they're just held in with a clip on the shaft, if anyone knows different, help me out here) and swinging the knuckle out.
    -remove any wiring to the diff, and the bolts that hold the diff in place while supporting the diff with a floor jack to lower it down.
  3. Dec 7, 2009 at 12:23 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  4. Dec 7, 2009 at 12:23 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Pretty much. I've always removed the axle from the spindle before removing the differential end. Just easier to maneuver everything that way. The outer axle has a 35mm nut that you'll have to remove.
    Drain the differential before removing the axles or you'll have a mess on your hands. And unfortunately, prying is the only way to get those axles out. They're really not difficult to remove but getting the right leverage can be a hassle. Just stick with it. When you get aggravated, take a beer break and then get back into it.
  5. Dec 7, 2009 at 1:04 PM
    jerris
    jerris
    utah
    thanks what is a SST?
