How Do I Remove The GAUGE Cluster?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RAD, Oct 24, 2009.
  1. Oct 24, 2009 at 1:40 AM
    RAD
    RAD [OP] Well-Known Member Vendor
    Rad
    LAX & LOGAN
    I'd like to remove the GAUGE Cluster in order to properly remove the Silver Gauge rings. I know they can be pulled off without removing the cluster but I fear in nicking up the outside.
    If anyone has the best way to remove the Silver Gauge Cluster. Please do let me know and shed some light on it for me.
    Thanks
  2. Oct 24, 2009 at 2:04 AM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
  3. Oct 24, 2009 at 4:58 AM
    sockmonkey
    sockmonkey Well-Known Member
    Greg
    Benbrook, SW Fort Worth
    2007 White Dbl Cab Pre-Runner
    Volant Ram Air intake,URD MAF calibrator, Mr Marv 10" sub box, Alpine HU, Alpine Amp, fog light mod, scan gauge II, RAAMmat front and rear doors, Wet Okole seat covers, blacked out dash. blacked out front bumper. American Racing Mojave Teflons wrapped with 265/70/16 Pathfinder AT. NST Lite Pulleys
    1. pop the door sill.
    2. remove driver kick panel.
    3. pull out right hand "pocket" next to steering wheel (pull straight out, sharply)
    4. then unscrew the 2 screws holding the lower portion of the dash (another sharp pull towards seat)
    5. remove the top plastic fasteners directly above the gauges (shown in the customtacos link)
    6. again pull sharply to remove upper portion of dash
    once you have that off, there are little "tabs" that you will need to use a flat head screw driver blade or spackling blade
    the rings are not glued or plastic riveted on.
    very easy to get to
    REDdawn6 likes this.
  4. Jul 12, 2014 at 10:30 AM
    toast
    toast Well-Known Member
  5. Apr 2, 2018 at 9:21 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    How about just getting the silver rings off?
  6. Apr 3, 2018 at 7:52 AM
    sockmonkey
    Greg
    from what i remember......there are tiny clips that you have to lift, with a flat head screw driver or blade, from the back side
  7. Apr 3, 2018 at 9:35 AM
    20somethingwidataco
    Will
    Washington State
    Ah, so you do have to remove the cluster to get them off?
  8. Apr 3, 2018 at 11:39 AM
    sockmonkey
    Greg
