how do I remove the rear door handle ??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by seareef, Nov 18, 2009.
  1. Nov 18, 2009 at 2:02 PM
    seareef
    seareef [OP] Well-Known Member
    Ron
    Lake Elsinore CA
    Bitch Magnet
    I figured out the front no problem but the rear is stumoing me ' can anyone help ?
  2. Nov 18, 2009 at 2:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Right near the bottom.
  3. Nov 18, 2009 at 2:27 PM
    seareef
    Ron
    Lake Elsinore CA
    Bitch Magnet
    man chris i removed both torx screws from the inside and I still cant slide that inner assemble off or remove the outside handle , I am missing something or its just being stubborn
  4. Nov 18, 2009 at 2:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    With the outside handle cover removed, you should be able to move the handle tward the rear, and pull out......
  5. Nov 18, 2009 at 2:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It says the release plate must be pulled, and held while doing this.
  6. Nov 18, 2009 at 2:32 PM
    seareef
    Ron
    Lake Elsinore CA
    Bitch Magnet
    Got It.. it was just being a little stubborn once i touched the inner clips it poped right out
    THANKS CHRIS u the man
  7. Nov 18, 2009 at 2:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  8. Feb 3, 2010 at 6:18 PM
    BreezyTaco
    BreezyTaco Well-Known Member
    Corpus Christi, TX
    Pioneer Indash GPS, JL Audio Speakers, FM Alarm, Euro Tail lights, Blue Dash Lights, Trailor Hitch, Painted Fiberglass A.R.E. Tonneau Cover
    You have to remove all of that stuff just to replace the outside handles? I just picked up my color matched handles from the dealership today, waiting on the Fat Mat to arrive and hopefully I can get this underway, any tips would be great.
  9. Feb 23, 2011 at 3:14 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    No. The instructions I believe are for a rear door replacement.
  10. Sep 30, 2011 at 6:24 PM
    typete247
    typete247 Member
    Tyler
    Hattiesburg, MS
    05' Silver Tacoma
    This is the same situation I am in. If i figure it out, I might make a video, because this is no fun.
  11. Sep 30, 2011 at 6:46 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    Way to inflate his ego even more than it already is... :rolleyes:
  12. Feb 17, 2013 at 8:50 AM
    Sgtfluffy16
    Sgtfluffy16 Well-Known Member
    Corey
    PA
    07 Tacoma Double Cab TRD Sport
    20% tint, HID headlights/ yellow fog light bulbs and LED lights interior/exterior lights. 4.5 Inch RCD lift, 1 Piece custom driveshaft, AEM intake, Dynomax Exhaust, Amp research Moto-bed extender, Extang Express tonno.
    the link doesnt work anymore chris... how do I remove that handle? trying to get rid of this rust
  13. Feb 17, 2013 at 11:05 AM
    BreezyTaco
    Corpus Christi, TX
    It's been a long time since I've done this, but you have to remove the inner door panel. Start with the screw in the cup holder, or search for how to replace the rear speakers for instr. how to remove the panel.
    You have to remove the window arm to access the t screw. Once you get there it's easy but this was a super pain in the ass.
  14. Feb 17, 2013 at 11:54 AM
    Sgtfluffy16
    Corey
    PA
    door panel is off and plastic is pulled back... removed the 1 and only torx bolt that i saw in the handle but cant seem to figure out how to remove the handle
  15. Feb 17, 2013 at 12:11 PM
    BreezyTaco
    Corpus Christi, TX
    I found this on an old thread I wrote in.
    I just figured it out, and it is pretty easy...
    You remove the door panel by unscrewing the screw by the inside handle and the arm rest.
    Remove the window switch and D/C the plug
    You carefully pry out the panel, starting at the bottom closest to the cab of the door, and work your way up.
    Once the door panel is off you will see one screw holding the outside handle, unscrew that with a T-30 bit, next you will see a rubber piece hiding the screw to the window guide remove that, and with a 10mm socket unscrew the bolt, then unscrew the bolt above it by the window.
    Remove the wires that are by the window slide, it is a round thing that you can D/C with your fingernail. Off to the side there are 3 bolts holding the lock mechanism remove those and the lock should fall down allowing access to the bolt holding the end of the handle or where you could stick a key in. Unscrew that and pop out the end of the handle, I used a screw driver in between the handle and the little rubber piece.
    Slide out the gripping part of the handle and replace with the new ones. After all of that is done put everything back together. Hope this helps, and is my first little write up let me know if you have any questions.
  16. Feb 17, 2013 at 12:27 PM
    Sgtfluffy16
    Corey
    PA
    Im still stuck Im am at the part of removing t30 bolt.. only reason I am removing it is to replace the rusty nut that is causing rust runs on the outside of my truck around the door handle
  17. Feb 17, 2013 at 1:47 PM
    BreezyTaco
    Corpus Christi, TX
    My memory of this is not very good I'm sorry...can someone else chyme in to help out?
  18. Feb 19, 2013 at 8:34 PM
    Sgtfluffy16
    Corey
    PA
    never mind I figured it out thanks anyways
  19. Feb 19, 2013 at 8:58 PM
    BreezyTaco
    Corpus Christi, TX
    Great...it's just been so long that I did this I can't picture it in my head to help out.
