How do I remove transmission range sensor???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hurricaneredbone, Oct 7, 2017.
  1. Oct 7, 2017 at 9:45 AM
    hurricaneredbone
    hurricaneredbone [OP] Active Member
    Mark
    2008 Desert Sand Mica Tacoma 4x4 base
    3" lift, OME nitrochargers, Tuff Country UCAs 32" BFG KO2 Trail Gear bumper Camper top + roof rack
    I have a CEL code for a transmission range sensor. These things are stupidly overpriced, so first I want to take it off and give it a thorough cleaning and hope it fixes it. Theres one bolt that aligns it and then it seems to be attached to the gear shifter axle thing. I don't know how to get it off of it. In the pictures I have seen it appears to have a slotted hole that slips over the shifter axle, but on mine it seems to be one piece... am i just seeing it wrong and its just seized onto it and needs a little roughhousing to wiggle off? Insight would be appreciated. Thanks!
  2. Oct 7, 2017 at 10:02 AM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    What's the code?
    Just start by disconnecting it, clean the connector end and the component end with electrical cleaner, plug it back in. Do a hard reset (batt disconnect) and see what happens.
  3. Oct 7, 2017 at 10:39 AM
    hurricaneredbone
    Mark
    Ok Ill do that first. But can you still tell me how to remove it in case that doesnt work?
  4. Oct 9, 2017 at 9:39 PM
    hurricaneredbone
    Mark
    So i cleaned the connection, it seems to help but not completely fixed the problem. I spwsnt to remove and clean but hoe do it remove it?
  5. Oct 10, 2017 at 1:46 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    TacoBirr and tomwil like this.
