How do I stop the beeps when I lock or unlock my Taco?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmed99, Feb 13, 2009.
  1. Feb 13, 2009 at 10:38 AM
    #41
    Shiftin2Sixth
    Shiftin2Sixth I'm crackin eggs of wisdom
    Curt (kûrt)
    Rialto, Ca
    2018 White TRD Sport AC
    My buddy and I clipped the wire to his buzzer on his 03. No problems so far but it was on the older model.
  2. Feb 13, 2009 at 11:52 AM
    #42
    jmed99
    jmed99 [OP] Well-Known Member
    SC
    09 DC PreRunner TRD OR
    I just took my Taco to my buddy that owns an Audio store to get the Valentine1 and TomTom hardwired...he advised me not to cut the wire to the piezo buzzer. He said they'll have more than one thing running in a wire sometimes and when the stealership connects a computer to it it will show up therefore voiding part of my warranty.
    Those are good points so I don't think I'll cut the wire. I guess I'll wait until the next time I'm at the stealership and pay them $90 to do it. :(
    Sethandmarg likes this.
  3. Feb 13, 2009 at 11:57 AM
    #43
    Blackened Taco
    Blackened Taco Well-Known Member
    Tony
    Virginia
    2005 AC 4WD TRD Sport Tacoma Speedway Blue
    3 inch suspension lift, 16 inch TRD FJ Cruiser black alloys, 33 X 12.5/16 Swamper Trxus M/T, Line-Xed Toyota skid plate, TRD exhaust, TRD cold air intake, Full tint to match factory tint, In channel wind deflectors, Custom wired hidden XM, Black shorty antenna, Black background headlights, Sockmonkey TRD decals, Kenwood 5120 HU with navigation, Boston Acoustic SL60 front compnonent speakers, SL65 rear speakers, Grillcraft lower mesh grille, Black badging, AromorTech Offroad rear bumper and rear shackle flip kit Access tonnosprt cover, 12 volt power adapter wired in under the dash for standard plug in items. Recently added Devil Horn Toyota Logo, Thanks Andres.
    Step one: Open the drivers door and insert the key into the ignition
    step two: Remove the key from the ignition and, within 5 seconds,
    reinsert the key back into the ignition and switch to the on position.
    Step three: After 10 seconds, the system enters the answer-back mode
    step four: Within 10 of the answer-back beep the switching mode is
    started, press the remote twice and teh system will turn off
    or on based upon which the system is set.
    tacoma2g, Orco59 and Arkie-Marty like this.
  4. Feb 13, 2009 at 11:59 AM
    #44
    jmed99
    SC
    Did this work on your 05? How do you know it will work on our 09's????
    Thanks for the help! :D
  5. Feb 13, 2009 at 12:01 PM
    #45
    weihenstephaner
    weihenstephaner Well-Known Member
    Atlanta, GA
    2009 4x4 TRD OR DC SB Mag Grey (SOLD)
    Bought a Tundra
    That solution got posted before in this thread, but never confirmed. I'll give it a shot this evening.
  6. Feb 13, 2009 at 12:05 PM
    #46
    jmed99
    SC
    How did you find that thread...I've been looking for something like this all day. :)
  7. Feb 13, 2009 at 12:11 PM
    #47
    weihenstephaner
    Atlanta, GA
    Bought a Tundra
    Googled 'answer-back mode Tacoma' after I saw blackenedtaco's post. It didn't come up when I searched here earlier because none of the keywords I thought of were in that other post.
  8. Feb 13, 2009 at 1:16 PM
    #48
    nd1979
    nd1979 2nd Tacoma
    Houston
    '15 DC TRD OR 4x4, Super White
    jmed99 and I could not get it to work for the life of me. If you can please let me know
    Thanks!
  9. Feb 13, 2009 at 1:26 PM
    #49
    zuter
    zuter Well-Known Member
    Calgary, AB
    09 SR5 4x4 4 cyl
    2nd filter, undercover, debaged, bug deflector, more to follow!
    Thank you, Blackened Taco! This works like a charm. And yes I have an 09'
    Someone should start a post listing all the tweaks that can be done like this one! That is if there isn't one already and if so this one should be added.
    Again, thank you!
  10. Feb 13, 2009 at 1:28 PM
    #50
    jmed99
    SC
    This works!!!! My beeping has stopped! Do this...
    Last Modified: 5-14-20085.1 DFrom: 200805Model Year: 2009Model: TacomaDoc ID: RM000000XXC01SXTitle: DOOR LOCK: WIRELESS DOOR LOCK CONTROL SYSTEM: CUSTOMIZE PARAMETERS (2009 Tacoma)
    1. CUSTOMIZING FUNCTION
    The following items can be customized.
    NOTICE:
    • When the customer requests a change in a function, first make sure that the function can be customized.
    • Record the current settings before customizing.
    • When troubleshooting a function, first make sure that the function is set to the default setting.
    • If the battery is disconnected, the wireless answer-back buzzer will be returned to the default setting.
    Item
    Function
    Default Setting
    Customized Setting
    Wireless remote control
    Operation signal (Buzzer)
    ON
    OFF
    (a) Open the driver side door and insert the key into the ignition cylinder.
    (b) Remove the key from the ignition cylinder and, within 5 seconds, reinsert the key and turn the ignition switch to ON.
    (c) After 10 seconds, the system enters answer-back buzzer switching mode.
    (d) Within 10 seconds after answer-back buzzer switching mode is started, if a transmitter button (the same button) is pressed twice, the answer-back buzzer setting changes (off to on, or on to off) to activate or disable answer-back by buzzer.
    HINT:
    • The driver side door is closed.
    • The ignition switch is turned off.
    • The key is removed from the ignition cylinder.
    • A transmitter button is not pressed for 10 seconds after answer-back switching mode is started.
    • The transmitter is operated but the second button pressed is different from the first.
    • Answer-back starts.
    Thanks to beeftaco!!!
    Jess-YODA-coma likes this.
  11. Feb 13, 2009 at 1:31 PM
    #51
    weihenstephaner
    Atlanta, GA
    Bought a Tundra
    Awesome. Can't wait to get off work to try this. And if I don't like it, I can disconnect the battery and get my beeps back. Beats cutting wires. :D
  12. Feb 13, 2009 at 2:01 PM
    #52
    nd1979
    nd1979 2nd Tacoma
    Houston
    I must be lame! I glad to see that it works. I will try again until I get this sucker quiet.
  13. Feb 13, 2009 at 2:30 PM
    #53
    Blackened Taco
    Tony
    Virginia
    If you do not like it just do the same thing and it will reverse the previous function. You can turn it on or off by using the directions.
  14. Feb 13, 2009 at 4:55 PM
    #54
    fishshooter
    fishshooter Well-Known Member
    Northwest Florida
    09 Super White TRD Off Road 4X4
    Stock
    Thanks BT and jmed99, the beeping WAS annoying, it's fixed now.
  15. Feb 13, 2009 at 8:36 PM
    #55
    weihenstephaner
    Atlanta, GA
    Bought a Tundra
    Hell yeah. Worked great, first time. No more annoying beeps. :thumbsup:
  16. Feb 14, 2009 at 10:39 AM
    #56
    Blackened Taco
    Tony
    Virginia
    I also have the procedure to kill the seatbelt buzzers also if you want that too just let me know.
  17. Feb 14, 2009 at 10:44 AM
    #57
    cakmakli
    cakmakli Finally made it - U.S. Army Retired
    Pittsburgh, PA
    09 TRD Sport
    Of all the advise that I have gotten off this forum, this is by far the best.
    Thank God, no more beeps.
    I just can't believe that Toyota wanted to change someone on here 80 bucks just to turn it off. What a friggin ripoff.
  18. Feb 14, 2009 at 12:05 PM
    #58
    fishshooter
    Northwest Florida
    Stock
    I'd like to know. Any ideas about the open door/ keys in the ignition alarm?
  19. Feb 15, 2009 at 12:10 PM
    #59
    nd1979
    nd1979 2nd Tacoma
    Houston
    I finally got it to work, I had the stupid door closed and it would not work! Thanks guys.
  20. Feb 15, 2009 at 12:23 PM
    #60
    AK27
    AK27 Well-Known Member
    some times i wish mine would beep so i didnt have to look for the lights to turn on. not a big concern though :p
