How do I stop the beeps when I lock or unlock my Taco?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmed99, Feb 13, 2009.
  1. Aug 20, 2009 at 10:48 AM
    #81
    flatlander
    flatlander Well-Known Member
    09 DC-LB 2WD Prerunner V6 Auto
    I have seen some instructions for programming the remote to open all four doors. I will try some searches and see what I find.
    I also want to keep the single beep for lock. So I was wondering, in step "D" it says to press the same transmitter button twice. Will it only silence the beep for that button or both lock and unlock regardless of which button is used?
    TIA
  2. Nov 9, 2009 at 9:25 PM
    #82
    magneticnick
    magneticnick Well-Known Member
    Nick
    Orange, CA
    2010 DoubleCab TRD Sport
    None Yet
    freakin awesome mod!!!!!
    I love this website!
  3. Nov 22, 2011 at 4:31 PM
    #83
    Vito Corleone
    Vito Corleone Well-Known Member
    Canton, Georgia
    2012 Tacoma TRD Sport 4WD D/C
    3" Lift, Flowmaster Dual Exhaust, 285/75/16 Michelin LTD On TRD Wheels, 20% Tint, Front Skid Plate, Agri Cover Tonneau Cover. Bed Mat, Bed Extender, Tinted Taillamps, Silverstar Ultra Headlamp, Foglamp, DRL/Turn Signal Bulbs, LED Map Light, Dome Light, Reverse Light, Tag Light, And Front Marker Light Bulbs, Stainless Side Steps, Locking Bed Storage Compartment, Foglight Anytime Mod, LED Daytime Running Light Strips (Same As On XSP-X Package), Heated Leather Seats, And TRD Supercharger With URD Pulley. More To Come ...
    Did it today. Worked perfectly. Thanks jmed99.
  4. Apr 10, 2012 at 12:13 PM
    #84
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    I tried this 5 times last night and must be doing something wrong...
    (a) Open the driver side door and insert the key into the ignition cylinder.
    (b) Remove the key from the ignition cylinder and, within 5 seconds, reinsert the key and turn the ignition switch to ON. (DO YOU THEN TAKE THE KEY OUT?)
    (c) After 10 seconds, the system enters answer-back buzzer switching mode.
    (d) Within 10 seconds after answer-back buzzer switching mode is started, if a transmitter button (the same button) is pressed twice, the answer-back buzzer setting changes (off to on, or on to off) to activate or disable answer-back by buzzer.
    HINT:
    The driver side door is closed.
    The ignition switch is turned off.
    The key is removed from the ignition cylinder.
    A transmitter button is not pressed for 10 seconds after answer-back switching mode is started.
    The transmitter is operated but the second button pressed is different from the first.
    Answer-back starts.
  5. Apr 10, 2012 at 4:31 PM
    #85
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Use the key next time.
  6. Apr 10, 2012 at 4:46 PM
    #86
    Super Black Taco
    Super Black Taco Well-Known Member
    Grayson
    Redwood valley, CA
    09 TRD SPORT 4x4
    OME 885 1/4 spacers,Dakars, 3* shims,Light Racing UCA BHLM,Wicked Flow Muffler, JL sub, Alpine amp, URD Short Throw Kit, U-Bolt Flip kit, 285/70/17 hankook mt
    YES!!!!!!!!!!!!! IM SO HAPPY I FOUND THIS
  7. May 3, 2012 at 5:17 AM
    #87
    FFMedic
    FFMedic Well-Known Member
    Drew
    Newton
    2012 Tacoma SR5 MGM
    Anytime fog, Upgraded sound
    I can confirm that this works for a 2012 as well. Since quite a bit of things have changed on the 12s. Went to the dealer today and he handed me the same instructions on a print out. He re-iterated that if the ECU loses power this must be done again as it will default back to on.
  8. May 3, 2012 at 7:53 AM
    #88
    StickShifty
    StickShifty Well-Known Member
    New Jersey
    2012 AC 4WD 6SPD
    i did the electrical tape over the little box, it cut the "beep beep" sound way down. you can still hear it beep very faintly. 2 min mod, good enough for me.
  9. May 3, 2012 at 11:45 AM
    #89
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    Take the "box" right out ... tape over the plug ends ... no beeps ...
  10. May 3, 2012 at 11:50 AM
    #90
    prerunner11
    prerunner11 Well-Known Member
    MD
    2011 Magnetic Grey Prerunner Dbl Cab Sport
    Softopper
    I tried doing this on my 2011 four times in a row with no success. Even weirder, after I was unsuccessful on the 4th time, I tried to start up my truck and the RPM's went up to about 2/2.5 and then back down to 0. Seems like it reset everything electronically or something? Any insight? I'd like to get rid of the unlocking beeps.
  11. May 3, 2012 at 3:20 PM
    #91
    jpmorrisvb
    Jimmy
    Virginia Beach
    Gee ... let's look at this again ...
  12. May 3, 2012 at 3:39 PM
    #92
    prerunner11
    MD
    Softopper
    Gee...I said lets get rid of the unlocking beeps, not the locking. Thanks.
  13. May 3, 2012 at 4:07 PM
    #93
    Ghoster
    Ghoster Well-Known Member
    Baltimore
    2012 PreRunner DCSB
    Success on my 2012. No lock or unlock beeps anymore. It would be nice to have kept the single beep when locked, but NO beeps are better than ALL beeps.
    Now if I could figure out how to shut up that seat belt chime. The instructions for that one don't seem to have any effect.
  14. May 3, 2012 at 4:43 PM
    #94
    prerunner11
    MD
    Softopper
    Wait...I could you could only disable unlock or lock, not all or nothing.
  15. May 3, 2012 at 4:53 PM
    #95
    Ghoster
    Baltimore
    2012 PreRunner DCSB
    Seems to be all or nothing, at least it is on mine.
  16. May 3, 2012 at 7:27 PM
    #96
    FFMedic
    Drew
    Newton
    2012 Tacoma SR5 MGM
    That's a dealer function on the 1/2 year for 11 and all 12s. Spoke to the dealer and got them to disable that for me too at no cost! They have to use a Toyota specific scan gauge to change the setting. Some places won't do it at all and some will for a charge. Service tech did tell me that if the battery is replaced or gets to a low voltage state the ECU will reset and default to factory settings meaning another re-program.
  17. May 3, 2012 at 7:29 PM
    #97
    FFMedic
    Drew
    Newton
    2012 Tacoma SR5 MGM
    I heard that this can cause power window malfunction; has this happened to you yet?
  18. May 4, 2012 at 4:26 AM
    #98
    jpmorrisvb
    Jimmy
    Virginia Beach
    Two years and going strong ... effortless, quick, and easy ...
  19. May 26, 2012 at 6:33 PM
    #99
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    I did this yesterday...no more beep!
    :D
  20. May 27, 2012 at 7:05 AM
    #100
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    If you dont like the beeps because it draws attention to your ride, then trick it out so when everybody looks at the beeping vehicle they go WOW nice Toyota! :D
    I personally like to know the truck is locked as I walk away and do not mind the beeps...
