How do I tell if a Tacoma has the factory towing package?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ShaLor, Jan 23, 2010.
  1. Jan 23, 2010 at 12:43 AM
    ShaLor
    ShaLor [OP] Well-Known Member
    Shane
    Burbank, CA
    07 4x4 Doublecab TRD Off Road
    Custom mud flap removal from rock on trail :), Tailgate Hose Clamp Mod, Cobra 75 wx st CB install, 19 more D-Rings in the bed, Satoshi Grill, Fog Lamp on any time mod. Relentless Fab CB antenna hood mount, LED bed lights, Demello Hybrid Sliders, Undercover Tonneau Cover, Lighted 4x4 switch
    I am trying to buy my first Tacoma. I am looking for a 2005 or newer 4x4 Double Cab with TRD Off Road package.
    I hope it also has the Factory installed towing package so my towing capacity will go form 5000 pounds to 6500 pounds.
    My question is:
    Is there a way to tell if if had the factory installed towing package by looking at it? I don't know enough about Tacomas to know what to look for under the hood as far as the larger alternator, larger battery, oil and transmission coolers etc.
    What should I be looking for as a tell tale sign that the truck I am looking at has it installed from the factory and not just the dealer installed hitch?
    Any suggestions and help would be greatly appreciated.
  2. Jan 23, 2010 at 12:54 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    There is a pic somewhere around of the trans cooler...the only real way of knowing on a used vehicle is to know what parts you are looking for.
    But a non-tow equipped V6 4x4 double cab in the United States has a tow capacity of 3500lbs, in Canada the same truck is 5000lbs.
  3. Jan 23, 2010 at 3:01 AM
    astral
    astral On my second taco now....
    Arizona
    2011 TX PRO
    The tranny cooler should be easy enough to spot. A mini radiator mounted in front of the normal one.
  4. Jan 23, 2010 at 5:47 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Oil cooler underneath the oil filter is the quickest and easiest to spot.
    docbrown, knottyrope and Konvict KROG like this.
  5. Jan 23, 2010 at 10:46 AM
    desert taco
    desert taco Well-Known Member
    You can also look at the battery on the 2005+ Tacoma with the Towing Package as it will be designated as 27F. Hope all the responses help.
  6. Jan 23, 2010 at 10:58 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Go to a Toyota dealer and have them pull the info for your truck???
  7. Jan 23, 2010 at 11:07 AM
    tegdog
    tegdog Taco Lover
    Indiana
    09 Tacoma Dbl TRD Sport
    ventvisors,seatcovers, bug shield,TRD CAI,TRD CAT BACK,blacked out emblems,bed extender, TSB leaf pack,Pro Dry filter, Grill craft upper, lower, & triangles, Hella 500 Black magics
    I think all the the round 7 pin plugs are towing package Tacos, I could be wrong but the round plug is what you need for trailer brakes so it makes since that they would only put those on trucks with towing package, someone chime in here I would really like to know myself now.
  8. Jan 23, 2010 at 11:16 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    All 3 above and the fourth item would be a heavier duty alternator. Aside from the hitch, these are the 4 things you get with the towing package.
    CookieMonster likes this.
  9. Jan 23, 2010 at 12:46 PM
    Fortech
    CANADA
    It should be noted that a group 27F battery comes standard on all trim levels of Tacoma's in Canada. Not sure about the Northern US States though.
    As for the 7 pin connector, it can be installed on a non tow pkg Tacoma so I wouldn't let that be a determining indicator - especially if viewing a pre-owned unit.
    Oil cooler and ATF cooler is the sure fire way at a quick glance. ATF cooler could be added easily, so be sure to check for the oil cooler also.
    Rooblik likes this.
  10. Jan 23, 2010 at 1:36 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Is this the oil cooler mentioned above?
    CJP2x4x2, Hunter4950 and Konvict KROG like this.
  11. Jan 23, 2010 at 1:46 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    Yea ... that the oil cooler below the oil filter.
    CJP2x4x2 likes this.
  12. Jan 23, 2010 at 11:14 PM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    Don't forget that hot pink radiator fan shaft!!! At least on the '08's. ;)
  13. Jan 23, 2010 at 11:41 PM
    kanelakos
    kanelakos Well-Known Member
    Binghamton, NY
    16 DC LB Sport
    Personally, I would run the vin number to be sure. If truck is at a dealer, maybe the carfax would show it.
  14. Jan 24, 2010 at 6:38 AM
    Fortech
    CANADA
    Fan clutches are pink on most (if not all) models. My 2005 TRD OR non tow pkg has a pink fan clutch.
  15. Jan 24, 2010 at 8:24 AM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    Hate to have to ask this, but does that mean the MTs do not have the transmission oil cooler?
  16. Jan 24, 2010 at 9:55 AM
    BWro
    BWro Well-Known Member
    MT's dont have tranny coolers
  17. Feb 24, 2010 at 7:03 PM
    dbarn
    dbarn Well-Known Member
    Texas
    Tacoma 4X4 V6
    My 2010 Taco 4X4 Access v6 came with a frame mounted hitch but only the flat hook up vs the round. It also has the 27F battery and smaller radiator in front of the larger. I did not however see a oil cooler. Does this sound correct?
  18. Feb 24, 2010 at 9:44 PM
    Iamsheppy
    Iamsheppy New Member
    Asheville, NC
    '08 Tacoma V6 SR5 4x4
    Purchased my 2008 Tacoma last month, and due to a rather hectic schedule I am only now getting to go beneath the hood. It supposedly has the Towing Package, but I am finding what dbarn is - frame mounted hitch, flat hookup, 27F battery, smaller radiator situated in front of the larger, and no oil cooler. Also, fuse in front relay box is 120 - read somewhere it should be 130. What gives? Is this a true Tacoma "Towing Package"?
  19. Feb 25, 2010 at 4:11 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Probably not a factory tow package. Some dealers will install a tow package after the truck arrives from the factory.
    Flat trailer plug is not factory. Aftermarket trans coolers are cheap and easy to install. The oil cooler is unique and would have to be ordered from toyota and is $500 most places I have looked.
    So the dealer or someone probably installed this tow package, but it did not come from the factory like that.
  20. Feb 25, 2010 at 4:11 AM
    dbarn
    Texas
    Tacoma 4X4 V6
    Perhaps the oil cooler was left off of some towing packages. Glad to have the heavy duty battery and tranny cooler. How do you tell if you have the more heavy duty alternator??
