How do I tell when I need new ball joints?
Discussion in 'General Automotive' started by ClarencePeterso, Jun 30, 2020.
  1. Jun 30, 2020 at 3:48 AM
    ClarencePeterso
    ClarencePeterso [OP] New Member
    Clarence
    Are there certain noises or signs I need to look for? Or certain things I can feel when turning or driving?
    Thanks.
  2. Jun 30, 2020 at 3:58 AM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    Welcome to the forum! :hattip:
    There may be indications while driving that your ball joints are worn beyond limits and need replaced, but the only real way to tell is to try to manipulate the ball joint and check for play in it. Since they’re under tension and compression virtually all the time, it’s best to do this with a pry bar.
  3. Jul 1, 2020 at 6:00 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    In some vehicles (like the ~35,000 1st gen Tacomas still on the road), the ball joint will wear out without noise or change in feel. The only reliable way to detect a worn ball joint is typically to jack up the vehicle by the frame and stick a pry bar under the joint to check for play, like this:
