how do i turn off maint. reqd. light!??!
Discussion in 'Lighting' started by Austin523, Jun 22, 2009.
  1. Jun 22, 2009 at 8:22 PM
    Austin523
    Austin523 [OP] New Member
    riverside ca
    4.7L sr5 tacoma
    readylift leveling kit, custom intake, flowmaster
    duz anyone know how to turn the maintenance required light off.
    i took it in for an oil change and they didnt turn it off and its a paint to take it back in.
    sooo n e suggestions? thx
  2. Jun 22, 2009 at 8:24 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
  3. Jun 22, 2009 at 8:27 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    To reset you Maintenance Required light:
    1. Turn the ignition key to the "OFF" position with the odometer reading shown.
    2. Turn the ignition key to the "ON" position while holding down the trip meter reset knob.
    Hold down the knob for at least 5 second. The odometer indicates "000000" and the light goes off.
    NOTE: You will see a series of dashes that count down while the system resets itself
    If the system fails to reset, the light will continue to flash!
    You must re-perform the procedure
  4. Jun 22, 2009 at 8:44 PM
    Austin523
    riverside ca
    4.7L sr5 tacoma
    it worked! thx haha
  5. Jun 22, 2009 at 8:53 PM
    thekidcatcher
    thekidcatcher Well-Known Member
    Waco, TX
    05 TRD offroad SR5
    Legs- --Helo rims --Duratrac 285/75/R16 --Bilstein 5100 in front with OME 886 --Dakar with extra leaf --Total Chaos UCA's --5165's Bilstein in the rear Electronics- --Warn M8000 w/ Warn wirless remote --Cobra 29LTD CB, --12in sub with alpine amp , --Dual Battery, --Warn Air compressor --URD MAF sensor, --touchscreen cd player hooked up to front and rear cameras Armor- --All-Pro offroad front/rear/rocksliders --AP skid plate, diff armor Cajones- --JBA headers, midpipe, exhaust --Safari Snorkel --4.56s Misc- highlift jack --UWS toolbox --u bolt flip kit --Tepui Kukenam Custom- --in dash inverter --on-board shower system --dvd anytime mod --custom bed rack and tiregate.
    another thing for this, most common problems have already been talked about or had thread on them, do a little research, it goes a long way lol ;)
  6. Jun 22, 2009 at 8:54 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    Oh and welcome to TW. We gotcha covered.
    ^ for what you have just done has also been covered. We decided if that is the help you give just don't post. Not bitching just informing.
