How do I turn up my volume up???
Discussion in 'Audio & Video' started by rzimm001, Oct 14, 2009.
  1. Oct 14, 2009 at 1:22 PM
    rzimm001
    rzimm001 [OP] Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    Question for you audio enthusiasts. I have a pioneer DEH - 2100IB head unit running four infinity 6 1/2 component speakers. I also have an alpine subwoofer 10" type R in a custom made enclosure. Powering the sub is a sony slim line class D amp with rca cables coming from the head unit to the amp. My problem is that the speakers get plenty loud before the sub woofer gets loud. I've tested the sub with pure bass frequency and it gets real loud so I know the sub works. Any ideas how to get this sub to match the speaker volume? There appears to be no subwoofer adjustment on the deck and the gain is turned up to about 2/3 maybe 3/4. Help.... Thank You
  2. Oct 14, 2009 at 1:31 PM
    Tat2dTaco
    Tat2dTaco He who breaks things.
    Ricker
    San Antonio, TX
    05 SWB Prerunner
    Camburg Spindles All-Pro Expo Leafs Bilstein 5100s and 7100s DTF Pre-Runner Bumper Tons of other crap
    if i understand you correctly, you just want your sub to be louder, right?
    well if im not mistaken, your HU only has 1 pre-out (dunno if it's front or back) but which ever the case try fading to the rear and turning the volume up.
  3. Oct 14, 2009 at 1:57 PM
    rzimm001
    Bobby
    Wildomar
    True... But than my sound stage is goofy because the rear speakers will also be turned up louder than my front speakers and I don't want that.
  4. Oct 14, 2009 at 1:59 PM
    Gossamer
    Gossamer Howard Roark
    do you have a built in EQ that has that particular range set very low or is overriding the gain you have you amp set at...for example, on my alpine, I have an eq setting that if I turn off, gives me more bass than when the signal is processed through the eq.
    also, does your HU have a built in crossover and what's it set at...is it turned on/off?
  5. Oct 14, 2009 at 2:01 PM
    Tat2dTaco
    Ricker
    San Antonio, TX
    05 SWB Prerunner
    unfortunately thats the only way i know. hell short of taking out your rear speakers, but your best bet is to eventually get a HU with 3 pre-outs. hopefully another member can expand on this. if you take out the rear speakers and boost the sub it sounds pretty good, i have my mustang set up that way.
  6. Oct 14, 2009 at 2:03 PM
    tacobell007
    tacobell007 Does that have the v6?
    Drew
    Westfield, MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, adjustable Bilstien 5100's up front, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Kenwood 350 watt amp, stickers, Better Built toolbox, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 33x12.5x17 General Grabber AT2, Fuel Off-Road Trophy d551 in 17x8.5, BHLM, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro Dry-S drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear plate with swing out and full size spare, SOS bolt-on sliders with kickout, 20" LED bar on main hoop, flush mount pods in rear plate bumper for aux reverse lights
    tone or a button by balance should let you change the level of bass and treble output
