How do I wire a SPST switch?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by monsterkx2fiddy, Jan 24, 2013.
  1. Jan 24, 2013 at 7:25 PM
    monsterkx2fiddy
    monsterkx2fiddy [OP] Well-Known Member
    Birthplace of Davy Crockett
    So im trying to wire my abs mod to a lighted switch (3 connectors)
    Obviously im retarded because the switch is NOT turning my abs backs on.
    Can someone help me out? How do i wire my abs to run off a lighted switch? I need every detail lol
  2. Jan 24, 2013 at 7:25 PM
    monsterkx2fiddy
    Btw I think I need this fixed tonight? So I can go to school early in the morning
  3. Jan 24, 2013 at 8:10 PM
    monsterkx2fiddy
    well things got worse.
    I decided to just give up on my kill switch.
    But now my abs light is on, my parking brake light, my trac light, and maint req flashes on start up. So wth did I get myself into?
  4. Jan 25, 2013 at 6:52 AM
    fritzthecat
    fritzthecat Well-Known Member
    Virginia Beach
    07 PreRunner Auto AccCab Indigo
    Which modification scheme are you trying to do?
    Most require a DPST switch.
    Possibly your IG1 10A fuse is blown.
    Fritz
  5. Jan 25, 2013 at 7:07 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Maint. Required light is probably just coincidence. That's just a dummy light that flashes on start up when you cross 4,500 miles since last reset and goes solid at 5,000 miles since past reset.
  6. Jan 26, 2013 at 7:09 PM
    monsterkx2fiddy
    I was wiring abs switch. I found out on my own. I found which part of the wire was sending positive/negative feed. Then used that for the switch. Just in case anyone is wondering how to put abs on a lighted switch or ywm. The positive feed is going to the connector. So run that to the positive of switch. Then the auxiliary part of switch to the part of wire going to the connector. Thank you all for trying to help me
